The limit is 30 amps at the dock. The way co-generation works is that the unit actually can sync its phase to shorepower, generator, etc... This allows it to supplement what is there. If I'm pulling 25 amps from shorepower and up against the breaker and suddenly the water heater cycles on, instead of blowing the breaker the co-generation can supplement the remaining 10-15 amps through the inverter. So lets pretend the load continues at 15 amps for another 5 hours, I only rack up 65 amp hours out of the house batts. Compare to one of those great "American" units. On an outback and others, they can't co-generate but they can switch to the inverter. So lets do the math, I'm trying to pull a peak 40 amp load. If I run on the inverter I'm racking up 200 ah in 5 hours. Huge difference but more importantly, If I'm running a typical 2500 or 3000 watt inverter it can't run that load for that long and maybe not at all.
Yeah, so for a guy limted to a single 30 amp shore power connection at the dock, it's a big deal.
Bob, I'm hearing some fruitful rumors that Victron has just changed their distribution system in the US. I think we are finally going to see a number of dealers popping up. It's about time. Maybe the competition will get those wonderful American's to stop sitting on their hands and start innovating again.
bp
