Let's Talk HOUSE Batteries
captcraig
I have presently 4ea 6volt batteries rb2@gr5t105 amp hours. This gives me 2 banks with a total of 210 amp hours. My problem is that it only gives me 10 - 15 hours of life before I need to do a major charge.
Any battery recommendations? I am looking at Trojans which are 220 amps at $129.00 on LI, NY. Any better batteries or pricing available?
Better batteries will certainly help but have you done all you can to reduce your loads?
I'm changing out most of my lights to LED to get more life out of the batteries.
Hard to beat Trojans as house batteries on cost per amp hour. Do you have room to add a third bank?
golf carts batteries make for good inverter/house banks. Prices have gone up though, like most batteries... each give you around 210AH at 6v. Havent bought any in almost a year, Exides were around $100 a piece last april, best price i could find in town from a Golf Cart guy.
4 of them in Parallel/series will give you 440AH. what kind of boat/loads? 8 of them run my full size GE fridge/freezer (home size, 18cuft?) for 20 hours.
Most 6v golf batteries are good for about 200-220 amp hours. My guess your battery bank is about 400-440 amp hours, not 210. How old are your batteries?
I personally like Trojans but I'm not sure they're any more cost-effective than the cheaper big-box brands.
I have 6 of them (Trojans) and they're good for at least 2 days, running my apt-size 120v fridge and misc electronics and LED lights. In decent weather with the solar panels running there's no limit.
Probably the best thing you can do to extend your run-time is change out your lights for LED's and fluorescents.
Besides my genny battery; I only have two AC Deep Cycle Delco Voyagers that power up each engine & share house needs. Two total! They are each: M30HMF Marine CCA=625, MCA=900, Reserve Capacity (min.) 160/115AH, $124.95. Completely maintenance free.
I am going to convert all the lights I can with in reason to LED's. I am also considering adding another 12V 27A battery to my single 27A house battery. I am hoping this will be enough to get me through a weekend on the hook. I may buy one of those LED all around lights and find a way to clamp it to the real anchor light when needed since I can;t see spending $600 for an LED replacement light plus find a way to construct a new light mount.
I am also looking to get a few other gadgets - battery powered LED lantern and a portable radio that my Sirius can play to so I wont waste the house batteries running the stereo when staying on the hook overnight.
I have 2 8D batteries for the house and 2 4D for diesel starting. When I need to replace the 8D batteries I will go to pairs of Golf carts as the weight of the 8D's is too much for me to handle alone and slugging 2 6 volts I can do.
I have a golf course across the street from our newest development and I know the owner so I am going to ask him about his supplier.
one adds volts or amps but not both when connecting batteries.
jan
"I personally like Trojans but I'm not sure they're any more cost-effective than the cheaper big-box brands."
Yea, what I should have said was it's hard to bet golfcart batteries on a cost per amp hour basis. :-)
If you have the height available, look into L16s. Almost double the AH in the same footprint.
George
Rob,
superbrightledsdotcom has LED bulbs that may suit your needs at a very reasonable cost.
LEDs are one of the best replacements and power savers one can do on a boat. My boat had over 25 interior lights I replaced them all I went from drawing in excess of 20amps with all the interior lights on to 2 amps + or - .5amps. Changing the navigation fixtures that also dropped my current by at least 50%. I have had a interior lights changed for 3 years now I have only had 3 failures on walkway lighting fixtures. This year I bought a pair of high power Lumitec spreader lights they draw 1.8 amps each instead of 8 amps each the old lights drew they are brighter. I am also adding 4 blue high intensity power LED transom lights they are so bright you can not look at them out of the water, can't wait to see them in the water.
Here is a DC power saver that is hard to find. Feit Electric 12 Volt 13-Watt CFL Marine Light Bulb BPESL13TMAR12V. When you want a lot of light inside the cabin, they can't be beat.
This is a compact fluorescent bulb that replaces the marine 12-VDC bulbs that look exactly like household light bulbs. I also use LEDs and sometimes a marine oil lamp inside the cabin.
http://www.blacklight.com/items/BPESL13TMAR12V
Definately L 16 (Rolls 460/530 amp hours rb2@gr5t 114/126 lbs per battery!) or traction batteries are higher capacity, and in some cases a higher quality battery.
He realistically has 210 amps, if he is only discharging the bank 50% as he should be.
I have usually added two to 4 more golf carts when in the same situation--especially if you have to power 110 Volt refrigeration. Check the weight of the golf cart--the better battery will have more lead, and weigh more. I have found that the big box club batteries weigh less than Trojan--and probably in the long run the Trojans are a better deal....
