Lifting a large boat
missnmountains
We just closed on a new lot in Cape Coral only minutes from the Gulf. We tried to take advantage of the down real estate market. We plan on building a new house but not for a year or so.
My question is whether or not we can lift our Sundancer. I have found numerous companies that manufacture boat lifts up to 100,000 pounds. We would need about a 40,000 pound lift.
My concern is that I am told the boat can "droop" as it sits on the lift. Is this true?
Do any of you know whether lifting a 48 sundancer will work? It has been a PITA bottom cleaning etc.
As usual, your help is greatly appreciated.
Yes definitly. Most good boat lifts are designed so the boat sits and is supported as if it is on a trailer. For example, my lift has a 6000lb capacity and is basically two steal I-beams with a cradle rigged on them. The boathouse was built to hold it, so it simply hangs via steal cables. Using variations of larger I-beams, bigger motors, thicker cables and larger pilings, you can easily configure this type of lift to hold very large boats.
Bill, I appreciate your comments, we have a 16,000 pound lift where we kept our old boat.
The issue I am told is the bows on the larger boats have a tendency to droop because it is not supported. Your lift and my 16000 pound lift only support the keel, but our boats were much lighter.
The underlying issue is whether or not the bow would droop over time? I was told this by a yacht manager (100ton captain). I am just checking to see if any of you had heard of this before.
Thanks again.
There is a place in SW La. called Lunmar Boat Lifts.
Find their number and talk to Mark, the owner.
If he cannot help you, he can tell you who to call to find
what you are looking for.
Yes big lifts need to be designed to properly support the boat but that is common to large lift designs.
A lift would be a great solution to many problems but not storms since they tend to swild around in high wind and high tides may float them off. Nothing is easy.
Interesting on the "bow droop". Now that I think about it, there is a large section of my bowrider that overhangs the lift, not an issue on a samll boat, but a large cruiser I guess could have an issue. Maybe a call to SeaRay?
the bow drooping? heck, if that was the case i'd be concerned about taking the boat in open waters! it all comes down to having a lift designed to the boat you need to lift... the lift manufacturer should know and Sea Ray shoudl be able to provide information about where it needs to be lifted and how far forward.
keep in mind there is very little weight at the bow of a boat, the structure should be able to handle that...
I've seen many lifts with boats even larger than that...
My neighbor lifts a 40 or so Azimut with a 40K lift, and the cradles are adjusted to fit the boat. Biggest problem he has is shallow water, to get lift low enough to get off and on.Make sure you run enough power out to the pier to handle 4 motors, and your boat.
mssmountains;
since you are in a pretty warm area, you'll have to make a snorkle for your A/C units to keep them running when the boat is out, you'll also need to go to a hard bottom paint as the abletive type is toast after a couple days in the sun. as long as the boat is out of the water except when used you'll be in good shape, if you leave it in for a month you will be amazed how much fun the bottom cleaning is.........lol. i'm a bit south of you and have a diver here every 6 weeks and it works pretty well. you can pay for a lot of diving before you recover the cost of the lift. i doubt its cost benificial, but if it makes you more comfortable to have it out of the water go for it. i have seen an alternative down here, its a plastic ring that goes around the boat, you fill it with fresh water so the boat is stored in fresh water. i dont have experience with it, but have to imagine it works well until the a/c unit starts running.
Vic,
Great comments, right now we are up a canal behind a lock. As a result, the water is somewhat stagnant. I could easily have the running gear cleaned every three weeks and that would not be enough.
The new place is tidal and should get us to a 6 week schedule like you (I hope) if we do not lift.
FYI. I stopped running my ac a long time ago because the growth clogged it up requiring an acid flush. We now run a dehumidifyer on four hours off four hours. That has been working great.
Good point on the paint.
I agree with the cost analysis. We are currently paying $120.00 per dive. It would take a long time to recover that.
My real concern is whether there is this "droop" they were telling me. I kinda don't believe it as Pascal said.
Thanks again for your replies.
I used to live off Palaco Grande in the cape and bottom growth wasnt much of a problem. The water is brackish in those canals as they have been draining lake Okeechobee again. I also remember a 47 Bayliner pilot house on a lift back there. Whenever they took it out they let it sit in the water for a couple of days to "settle" I was told. Hope this helps.
There's another option to stop barnacle growth.
There's a company in fort lauderdale that sells a dam that surrounds the boat, like a large tarp with floats all around, it sounds goofy, but I'm seeing more and more of them down here where the water is warm. Bur for sure, it stops growth completely.
shoot,
Just tried the first link and visitors can't review photos. Let me know if you want additional information and I can email you.
Andy
I see quite a few 40 and under boats lifted, but I have never seen anything large like our 48. I know it can be done, but I really am curious if anyone had heard of a boat like our "drooping". Andy post one of your photos on this forum. I would be interest to see what you did.
the water dam will work, i've seen it used down here, but it can't work with an A/C unit working. i'm certain the interior upholstry will fare much better in a/c over time
The Meridian 441 is 47' overall, 31233 lbs. dry. Golden designed the lift for the majority of the weight to rest on a keel support. The bunkers are raised and run the length of the hull were it is straight. I just subscribed to this forum, but I still can't post pictures. I will try tommorrow.
Andy
PS...hey, I finally figured it out!!
A lift can be properly designed for any boat. It doesn't matter what size or weight. Sea Ray can give the lift maker guidance on the support required. The lift maker should be insured & guaranty their lift is suitable for your specific boat. If they can't do that go to the next one. Any boat can be dry docked right? In theory the lift is nothing more then a raised dry dock position & should be just as well supported for long term storage. Many makers may even provide cradles for a specific model that can be incorporated into the lift?
We know a person who has two 50 footers on lifts--they are over 50,000 lbs each. These have been on the lifts for over 10 years with no problems. As for humidity--consider several of the "mighty Dry" marine dehumidifiers--the boat will be hoter, but it will keep the humidity down and under control.
The cradle can be built to fully support the boat.
I am beginning to believe that the boat will not droop and can be lifted without problem. I have been using dehumidifiers for years. They have worked great. We get about two to three years out of them around $200.00 each. We stopped using it when we got the 48, but after only 4 months the AC clogged up and needed an acid flush. I have now use the dehumidifier for almost 8 months without any issues.
