lightest , smallest 12v deep cycle
TopandKandi
8' dinghy with 28lb thrust trolling motor. Looking for the lightest, most amp hr battery I can find. Just using the dinghy to cruise the marina and run to the beach on the hook. Two/three hours use a day, not full speed and a week long smart recharge on board after that I think. Searching everywhere but hope someone has the answer already.
PS If the Galley Wench gets to the beach and has to oar it back, I'm gonna be hungry if ya know what I mean...
Thanks in advance.
Hmmm, sorta the wrong question. Here's the problem: exceept for the "exotic" batteries, you will be using lead/acid technology. And, in general, weight = capacity. The "exception" is AGM ( Advanced Glass Mat ), and of those, Optima came out first ( I think ) with the spiral cell batteries. The result is a highet capacity per pound ( at least, somewhat ).
So, the lightest type of lead acid battery for you will be an Optima. They would recommend a "blue top" for trolling motors. ( See their site for the tech specs ). I happen to like them for many applications, this one included, but they have a higher $$/Lb than standard flooded lead acid.
The problem for giving a better answer is that we need to know how much capacity you need to, "cruise the marina and run to the beach on the hook. Two/three hours use a day, not full speed". Without that I can't give a better answer.
do a search for Odyssey Batteries, they sell direct on ebay, we use them in jetskis, motorcycles and aircraft, they have the best power to weight ratio.
I use a Walmart group 24 on my dink. It's about 40#, but still manageable. I can launch the dink and be underway in 5 min or less. AGM batteries would probably be better (no spill) but this works for me.
I get easily 5 mi range with a 24# MK, and charge it by plugging it in to the batteries on the boat.
I am using the same type of setup , a 7'6 Titan with a 30 lb Minn Kota . The first year I used an old car battery that I had but it was heavy to lift in and out all the time. I found that even for a extra long weekend that I was using very little out of the battery . We use weaver davits and when I flip the dinghy up I have to remove the battery so I also would like to go to something small. This year I am thinking about going to a garden tractor size . I found one from the supplier that our company buys batteries from Power Max . The rep it coming in to our head office and he is to call me . The battery is 8.75 x 5.25 and about 7" tall ( 20 lb). The rating is 54 min rb2@gr5t 25 amp and it is a deep cycle. After I talk to him I will post his thoughts.I'm not sure how many seasons I could get out of one but I think it would suit my needs. I also looked at another from a battery store . It was slightly smaller and a gel type. They said that it was rated at 50 min rb2@gr5t 75 amp. ( I kinda wonder if they are right) Being a gel I should be able to mount it to the transom and leave it in all the time but it was pricey $150
Optima Blue Top Group 34 deep cycle. Sam's Club is the cheapest around here.
In general, marine batteries are rated at the 20 hour rate: A new 100 AH battery will provide 5a for 20 hrs. The AH capacity is less if the discharge rate is higher and greater if the rate is less than the 20 hour rate. This holds, basically, for the more exotic batteries. Battery life and capacity will be enhanced if you can recharge the battery promptly after use. Luck. Dale
KiDa's got a good point with the Optima 34. I just had to dump off my 4 year old dead U-1 Gel at my local Interstate distributor. They're big into recommending flooded batteries as they say they have the best performance. But when I told them it was for a "dingy" application, they of course agreed it had to be sealed. I got an Optima for $50 as it was "old stock". New, and full warranty, but the design had changed and they couldn't put it out for retail.
Finally, something for the boat I didn't have to pay double for!
If you want small though, the U-1's are pretty decent.
I've used a U-1 and it will run a small trolling motor nicely, if it's just a matter of getting to the shore and back. For "cruising", gunkholing or fishing I think I'd carry two of them, though. I still like my gp24 deep cycle; with the built-in handle it's no problem to lift in and out of the dink. Of course one could make a rope handle for the U-1, as well.
I have a question for Wille . You have been using the U1 size , how big is your trolling moter/ dinghy ? Did you use just a standard U1 or some type of AGM or deep cycle ? How long did it last you before chargeing. I was at Wal Mart today and see they have an Energizer AGM with a 31 AH rating . Would it be big enough for the trips to shore ( a dozen or so 5-10 min trips on a weekend with a 30 lb Minn Kota ) ? I am thinking that with a AGM I could mount it to the transom and leave it in when we flip the dinghy up on the davits.
I have used the U-1... mostly for tests (had it already). I used a 24# Minn Kota on a 10' plywood skiff. I didn't have any problems with it but I was concerned about how far it would actually get me (and back); so I replaced it almost immediately with a gp 24. If you're only going a couple hundred yards to the beach it's one thing, but rowing an inflatable a couple miles back from a fishing trip is something else.
The gp 24 with it's handle is easy to manage with one hand; the U-1 took both hands (Makes a difference getting in and out of the dink)
If I recall a 30# Minn Kota draws about 30 amps at full power. So 35 amp hrs would get you maybe an hour, depending on speed.
