Like in cuddy floor
dixiesscbelle
We have a 1985 HarborMaster we were green when we purchased it. Did research on the net but apparently not enough. Long story of problems. What is the best product we can get to repair the floor.? We used the marine puddy stick suppose to fix even underwater? But we think it runs farther up than we got. Is there a seal of some kind we can pour in there to stop any leaks? Also Boat dealer told us we were grandfathered in with the sewage system but there is no sanitation device in the boat and no holding tank. It is a Raritan deep head with the macceration and the deoderiser under it. I read on one of the USCG or other reports if a boat was resold it was suppose to be updated by the boat marina that sold it or they could be fined. Is this true? We could have been fined and thought we were okay. I even called back 2 weeks ago and they continue to say it is okay. We are looking at adding a Lectra/San sanition device. Any thoughts on this? The boat is a 36'. Thanks for any help. We are harbored at Alabama at present, Dixiesscbelle
You need to be more specific on what is your problem(s).
G
What type of boat is this? Are you talking about it having a soft floor? Sounds like you didn't get a survey at purchase time, and now are facing paying the piper. I don't think there is any kind of "grandfather" clause that lets anybody pump raw sewage overboard--you can only do that in the ocean. Electrasan treatment system is nice, but somewhat pricey, otherwise you need a holding tank.
It's very difficult to understand your issues. Try breaking them down into seperate paragraphs or seperate posts.
I think you have a head with no holding tank and it pumps overboard. This is bad, very bad. You can pump overboard if you are a few miles out in the Atlantic. Until then, you cannot. Therefore, either remove the head or get a holding tank. If the USCG sees this, they will not be happy.
What's with the "floor leaking"? Sounds to me like you have a hole in the boat.
Hey guys, let's be gentle with a new boater who is new to this forum! We were all there at one time ourselves. See her Profile for boat details.
Marilyn, it is a shame you didn't find/read this board first. You would have had a survey before purchasing your houseboat. And you would have been advised to not buy it! Also, we could have told you to never believe what a dealer tells you unless you can substantiate it prior to purchase. I don't know the laws in Alabama. Do they have a "Used Boat" Lemon Law. Probably not.
Regarding the flooring: You need to have this inspected by an expert to see how bad it is and what would be the cost to repair. We cannot answer your questions without examining the floor and the extent of the damage. If it has dry rot, the entire area needs to be replaced. Small areas of dry rot can be fixed w/o replacement, but this sounds like something more extensive.
Good luck to you and be sure to come back here with any and all questions regarding your boat! I'm glad to read that you have been perusing the CG Website. Be sure to study the Safe Boating Section before you take your boat out. If you take a local class, you will meet many helpful folks and learn a lot more than an Online Course!
I use boated at work (where I do most of my surfing...DOH!) and cannot view the profile.
The post title seems to indicate a leak in the floor "like in cuddy floor" and that the boat is a cuddy. A leak in the floor could indicate a boat taking on water...who knows.
We really need more information to be helpful. With some pics and a better description we could diagnose remotely and save the cost of hiring a professional.
Walshie, they have a 1985 40' Harbor Master. I think that is a houseboat?
Someone with your expertise would be able to fix this from remote instructions, but not all of us are experienced at repairing boats. I still think they would better off having a pro to at least inspect the area and advise them how to fix it.
very big yawn.... "take a boating course"... geez... how about answering some questions instead of that same old song !!!
1)- there are no granfather laws in marine sanitation... you get boarded and either the USCG or local cops find a head with direct discharge... BIG fines. you can either add a holding tank or a lectrasan. holding tank is cheaper but you need to pump it out... not a big deal. Lectrasans are convenient but they use some electricity (if you anchor out on batteries, that maybe an issue) and there are some places where you cant' even discharge treated waste. Plus if you anchor out and swim... i know the "Stuff" is treated but you dont' want someone to flush !
2)- in the meantime, you need to lock the seacock (if underwater) or put a valve in the line and lock that. Lock doesnt' jsut mean padlock, a zip tie is acceptable. do this now !
3)- floor... are you talking about the cabin floor,inside, or the deck, outside.
if cabin floor, just pull the rotten plywood section and replace with new. If you're talking about the deck, outside, it really depends. putty isn't going to work, it's just a bandaid. is the deck plywood covered with glass, you will need to cut out the bad section, replace the wood and then glass over (cloth and resin ! not just putty or resin.
but again it really depends on the damage and what materials were used.
take some pictures, upload them (liek on a free image site) and post them or the links so that we can take a look.
I see two seperate issues here
1) The flooring. Is this inside, or outside? Both are repairable, but the outside deck is more involved. Still DIY capable though. The bigger question is where is the water getting to the core from?
2) The head - Simply add a holding tank and be sure to have a means to locking the seacock.
There was a Harbormaster houseboat docked next to us. It had a bedroom under the main salon that had 5 foot ceilings. You literally had to walk on your knees to get around.This one lost bilge pumps due to a tripped breaker and had about a foot of water standing in that lower bedroom for a few weeks.
Welcome Dixie, you've gotten good answers regarding the sanitation issues. If what I described above is the case, you'll probably have to replace the floor in that bedroom as well as do some rewiring. Are you bringing it back to SC? We're on Johns Island. best of luck to you.
The Homeport is given as "Huntsville Alabama"--this will be on The Tennessee River system--maybe Wheeler Lake. You cannot directly discharge in these waters, and the boat dealer should have indicated that. Take legal action against the broker. There is no grandfathering. At least get a holding tank. There are drop in units, such as the SeaLand Traveler combination toilet holding tank. Put that in, plus a pump out fitting for now. The only problem with this is it is only 10 gallons. Otherwise you can put in a holding tank of what ever size you can fit--and where plumbing will work out. The Lectrosan is a problem, since you are on fresh water--it uses the break down products of salt water to provide the disenfectant. So you either have to add salt, or use a PuraSan, which is a slightly different technology. There are some places which are "no discharge"--that means zero black water, treated or not.
As for the floor, it is very possiable that the water is comming from a deck leak. This may be around a fitting. You have to fix the deck leak before fixing or replacing the floor. Tracing deck leaks is difficult at the best. There is a good possibility of some deck damage also--although you didn't have a marine surveyor when you purchased the boat (big mistake)--you can still get one now and get some ideas of what has to be done to fix the boat. I don't know if you have any recourse to the "dealer"--probably not--but at least you need to make a formal complaint about the head to the state of Alabama Board of consumer affairs.
Dixie: I have a 1987 47-foot Harbor Master and I had a problem with a LAKE in my cuddy cabin. After a time, I found that rainwater was entering the boat through the seam between the deck and the hull, under the rubrail on the starboard side. The caulking in the seam had apparently dried and fallen out. Removed the rubrail. Cleaned out the seam, recaulked and no problems since. Good luck. Let us know what your find.
Thanks guys for all the info. Forgot to say we purchased the houseboat in Ohio. We do have a holding tank now knew from all the reading we had to do something fast so we had already picked one up.I just find it hard to believe they can sell something that isn't up to code. Surely they can't be that backwoods in Ohio to think it was legal. I know that was from not enough research on our part.So our fault actually.Proves the saying don't trust a salesman!! And j thanks for that post it looks like our problem is down the middle of the bottom seam any ideas on that. We have been going over the boat sealing all the spots we see leaks may be coming from.
What is the hull made from. Is it fiberglass, steel aluminum or wood?
You just can't patch leaks where you see them. If it is a leak thru the hull, it needs to be fixed from the outside.
If you guys are very new to boats, then your best action would be to get a good local surveyor and let him/her tell you what condition the boat is in, and what you need to do to be safe and to protect your investment.
Good luck!
Capt Tom
Captr Tom
Two rules when purchasing another boat, regardless of where it is or who is the seller: 1], ALWAYS have a boat surveyed from a surveyor of YOUR choosing prior to buying; 2] NEVER believe what the seller tells you. Yes, salesmen lie, but so do private owners. Assume nothing without verifying prior to purchase!
Good luck, Dixie. Keep coming back with your questions and keep us informed of your results.
If the hull is solid fiberglass then the only way to treat the leaks is have the boat pulled out of the water, allow it to dry well, grind the fiberglass to good solid structure, and then fiberglass over the cracks that are leaking.
If you have a cored hull it could get very expensive. A cored hull has fiberglass on the outside and inside with and a core af balsa wood or foam sandwiched between the two layers of fiberglass.
If the hull is of cored construction then you will have a major repair job as it is likely that the core is waterlogged and the remedy requires taking off one side of the fiberglass, removing the compromised core, and then rebuilding with new core and fiberglass.
If you are lucky it may be that the hull has been worn and cracked along the keel line by beaching too many times and it will only require a haul and external repair of the damaged area. If this is the case I would suggest that you add at least a half inch of fiberglass on the ooutside of the hul at the worn patches tapered into the hull to provide strength and allow for future wear.
Like = leak?
So you think the leak is coming from the "middle of the bottom seam"? What makes you think that. I take that description to mean the hull itself, along the keel line. That part of the boat is usually not a seam, but layed down as a single piece when the hull is formed. I know nothing about this particular boat though. Water often wicks its way surprising distances. Very specifically, what makes you think it is the "seam", if there is one? What I'm getting at is whether it is possible the water is coming from further away and simply collecting at the lowest point, which is going to be the keel line.
Dry the boat, completely. If you can't, haul it. When dry, sit and wait, inspect and find the water source. Lay down paper towels to spot it easier.
bp
