When I put the boat in at the beginning of the season, port stuffing box was leaking, to the point where the section under the V drive would have water there. We Tightened it 1 notch and that reduced the drip substantially (maybe 20 drips/min). It's the original stuffing box and I'm not sure if it was ever repacked before I bought the boat 6 yrs. ago.
Now, with about 20 hours so far, it seems like each time I go out the dripping gets more pronounced when I'm back sitting at the dock.
The only way you get to the stuffing box is to pull the engine. The waste holding tank is on the port side, so you can't shimmy in there to reach it. Our season is short enough as it is without having to do something now. After my last trip, the bilge pump was cycling about every 4-5 minutes. Previous to that, it was a much longer time interval.
Considering tightening it another notch to see if that helps. Am I living on borrowed time before it goes completely? Does that packing material just disintegrate from shaft friction? I'm reluctant to venture very far from 'home' as a result. I'm assuming the stuffing box itself is sound, but it's just the packing material that's going. If/when there's little or no packing left, does that mean continuous duty on the bilge pump?
