Lofrans Scorpion Windlass
coatspiano
Hi all...
I recently purchased a used boat with an electric windlass, which I've never had before. It is a Lofrans Scorpion, likely from 1996. Lofrans has very little information on their website about it. My question is this... currently my rode is 90 feet of chain and no rope. I would like to have a lot more rode and my anchor locker is huge and still largely empty. Does anyone have this windlass? Will it pull up rope or do I have to stick with chain?Cost being the main issue but also a little concerned about weight as well. Thanks!
yes it will. you'll need to splice the anchor line to the chain for it to work seamlessly. use a piece of test line on your windlass gypsy before you purchase a length of anchor rode. 3 strand is the easiest to splice yourself.
once you've got it all in place, be sure that if you put out all the chain that you put at least 25 feet of rode out to absorbe any shock or you will snap the line if it is drawn tight quickly.
