Lofrans Tigres windlass
san
I Would like some opinions on Lofrans windlasses particularly the Tigres model.
Thanks Doug
I have had 2 tigres on a 65 foot tri. The boat is a term charter boat and we pull our anchor up to 3 times per day. overall I would say we pull 600 times per year. Have found them to be very dependable. I replace the gypsie when I replace chain which is about 3 years or maybe 1800 pulls.I expect 10 years out of it without doing anything but maybe brushes and gearbox oil changes. The current tigres did have a strange thing happen. The motor started to pole out (armature shifted until it was able to make contact with feild coils) I pulled the end off and found nothing wrong. put it back together and its been fine for another year. Parts are available. Has plenty of power. Is probibly a bit undersized as per the charts for our boat but does the job admirably. I have put extra ribs on the line side to give more bite on 1 inch anchor warp. We also use it to pull the headsail furling line which gets used 2 or 3 times a day as well. overall I can highly recomend them. I am also in favour of horizontal windlasses as I have found vertical ones seem to put twists in chain when used a lot.
Bazza.
Thanks very much Bazza, just the info I was after. Doug
I second Bazza's statements. I've had one for at least 15 years that still works great.
I have the tigres on my 42' sloop. It pulls up my 65lb claw anchor without any trouble. Make sure to use heavy gauge wires on the install. I would prefer a vertical capstan to horizontal because with a vertical capstan the wrap angle of chain around the gypsy is nearly 270 degrees. On a horizontal, the wrap angle is about 100 degrees. An added advantage is that the motor is usually inside the boat or anchor locker and less prone to damage.
