Long wide messages
baull
Anyone know why some messages on this forum are (apparently) 150 (or so) characters wide? So that you have to constantly pan back and forth to see the end of each line? (Like "2 30 amp hook up to 1 50 amp hook up", for example).
I've been unable to find a way to shrink them down to normal width; it's a real PITA to try to read.
two reasons - links that are too long and photos that are too wide.
If -you- are the cause, you can fix it:
Keep displayed pictures to less than 801 x 601 pixels in size.
Place URLs ( web site links ) inside html code ( ie: use the [ url=LINK GOES HERE]displayed message goes here[ /url] )
If you did not cause, you cannot fix it. Only the moderator and originator can fix it.
Or, you can place the actual url in double quotes and after an equal sign in the [url tag, like this (single quotes here, you should replace with double quotes):
Code:
Click HERE
and it apprears like this: Click HERE
Some bulletin board systems seem to take care of that better than this one.
I thought it sometimes comes from users with very high resolution settings and maybe wide-format monitors. I think it gets set when the offending message is posted. It is annoying though.
i agree very annoying. Dont those posters see the same thing we see? or dont they care???
What the sender/viewer sees is dependent upon his/her computer monitor settings. I keep mine set with large type, therefore do not get as many characters per line.
G
Mine is set fairly large as well yet every web site I visit anywhere is automatically adjusted to fit my screen, except BE.
