Looking at 1987 3807 Aft Cabin
Made the trip today to see the boat. Almost 60 deg here on the north coast. Boat has been out of the water for several years. Going to submit offer on Monday. Subject to sea trial, survey and inspection. All inside and outside furniture needs replaced. Also carpet inside and out, bimini, galley flooring, drapes, blinds, all inside soft surface. Bilges look clean. Engine hrs 526. Gen hrs 200. Boat needs washing and rub out and wax. Fresh water boat its whole life.
Noticed that engines did not have sea strainers. Is this a common practice for Carver?
Need help on locating fuel distribution panel.
Ron
The fuel switches are in the aft cabin closet. Our '88 did have sea strainers.
Sounds like that boat needs LOTS of work. Do you mind if we ask how much you plan to offer?
My first offer will be 12 thousand. If accepted, next stop spring time launch and sea trial, inspection and survey. This project would be fill in work for my employees. They could knock this out in about 300 hrs. Plus materials.
Ron
Ron,
Kenny (Ramsport47) may be better to answer this, but from my experience at looking at many 1980's era carvers and owning one that does not have sea strainers I think it is very common for raw water cooled version to not have them. The fresh water cooled models seem to have sea strainers. Is the one you looked at raw water cooled?
Eric
Correct, raw water cooling. Submitted offer today. Lots of work to do if this goes forward.
Ron
My '90 Santego does not have sea water strainers. Raw water 7.4 Mercruisers. I was surprised....
Offer accepted. When the weather improves, time for survey, inspection and sea trial. End of April most likely.
Good luck with this. Once you get everything done you want, you will have yourself a pretty nice boat.
The heads seem to be crown electric. Is this correct? Is water supplied from fresh water holding tank? Did Carver run PVC for the long runs, or did they use hose? Also could someone post a pic of the cushions located on front on the flybridge console. I believe they are missing. Also helm seat.
Ron
The heads are most likely Crown electrics. Good units and fairly easy to work on with re-build kits. I did both of ours.
I would assume you are using raw water to feed the heads. Easy to find out. You should have 7 thru hulls on that boat...3 to feed the engines and Genset, 1 combined for holding tank discharge, 2 to feed water to the heads and 1 to feed the AC units.
Back to the heads. Where would the thru hulls be located. If there are thru hulls. They must be easy to get to.
Ron
All the thru hulls are in the engine room. If I recall 3 are on the port side and all can be reached from the middle crawl space. 4 are on the port side and not easily accessible.
The sinks are close by. Any reason I cannot tap cold line? What about check valve?
Ron
On my current boat, I rigged up a system to have a fresh water flush when needed. The only time I use it is Sunday night when I'm closing up to boat to go home. I realized the only time salt water was a smell issue was the first flush when we came back to the boat on Friday night. The water in the feed hose gets funky.
That is what I want to avoid. Heading to the boat shortly. Todays project. Find water feed to both heads. Locate which front windshield will come out. Boat has no lower station. Gives me plenty of clearance to remove furniture. Start cleaning inside of boat. Temp here today near 50.
Ron
If you are moving to salt water fresh water flush is important to avoid smells. Sea strainers are a good idea in salt water. You might want to consider adding closed cooling to keep the salt out of the engines.
Don't get too involved before the deal is closed. Seen it happen.
Just got back from the boat. Found the sea cocks that feed both heads. Located by the engines. Per your instructions. Also located bimini, strata glass for aft deck and bimini sides.
Boat we put the deposit on happens to be located very close to our marina. So this weekend, with the weather being so nice. Worked on our boat and spent some time going over the Carver. We have started on a list of the things we want to change or improve. Launch looks to be first of April. Previous owner has started to remove his personal items. Title is clean with no liens.
Ron
The only reason I say this is because I know someone who installed canvas and went whole hog before the deal was done, and they lost everything.
No changes until the deal is done!
