Looking for 120 VAC Blower
TJM
I have an application at work where we need to evacuate the fumes from some mild solvents that have an extremely low flash point. I was thinking of a bilge blower and wondered if they make them in 120 VAC service?? I could always use a step down transformer rated for the app wattage, but 120 VAC would be much easier. This is a temporary condition that would only be in use about 2 hours per week. Its better than letting the operators get asphyxiated and the CEO does not want to spend the cash.
Buy an oscillating fan at a box store to ventilate the area.
I agree that asphyxiating the operators would likely be more expensive than an exhaust system. But I suspect that the "cure" will need to address OSHA rules as well as State and local fire codes.
Try asking about the blower at a commercial ship's chandlery. 120v blowers might be more common of the larger vessels ( I do not know. Sorry. )
You should have no difficulty finding an 120VAC blower at a hardware or building supply store. Plenty get used as exhaust fans for bathrooms, kitchen hoods, etc.
You can also buy inline 120 VAC duct fans that resemble the inline turbo fans used as bilge blowers. These push 100-500 CFM and cost $90-200, but might be a good solution for you. Look for industrial fans.
try a Google search for:
TD-Mixvent Series Multi-Purpose Inline 8" Duct Fan (476 - 538 CFM)
yzer, I'm not sure those fans etc you reference are suitable for air contaminated w/ low flash volatiles. They might be, but I don't know; have you checked?
( I'd like to hear a solution, because I'd like to use spray lacquer in a spray booth without violating every law in the county, or creating a firestorm in my face! )
You are right, Bill.
Disregard what I wrote above.
If you want to go OSHA (and I'm sure you and the boss do) you need an explosion proof fan. That's going to cost you some bucks. A portable paint booth fan might work or the little Jabsco fan mentioned above, if it's big enough.
Actually, if you do the Google search I listed above you can find links to a variety of explosion proof fans on the same page.
The Jabsco unit is not meant for gasoline engines / Flammable vapors. The application is a parts washer with a drain tray. There is about 1 gallon of the liquid in a Justrite flammable container. The enclosure is only open in the front where the operator stands. The oscillating fan would not work. My intention is to suck the fumes away from the face zone up a stack and out the building. The volume is under the air permitting requirements of the "clean air act" but the evaporated volume quantity is still collected and reported to the state. Ignition protection is a must, the blower motor will be in the fume stream. That is why I don't think an AC unit is available. DC is much easier to protect from stray sparks.
What about a system similar to what restaurants have to use over there cooking surfaces?
Go to Grainger, they have all kinds of explosion proof fans.
Geebee is correct grainger is the place.
WWW.grainger .com
Cost does have impact. The Blowers from CarlBush; although very very nice, are $900. The DC Marine rated blowers are around $ 60 max, add a DC transformer, < $100. Justifiable expense in this economy.
I have dealt with this type issue. It is important to ensure that you have greater CFM input into the space than you are trying to evacuate. In other words you need to increase the pressure in the space slightly so that the fumes take the path of least resistance out of the space - your evacuation blower. So to do this effectively you need TWO blowers one into the space, doesn't necessarily need to be explosion proof, and one to evacuate the fumes - this one needs to be explosion proof if the fumes have a low flash point.
You have to ensure that the adjacent spaces are well sealed from the space. You could push fumes from the work area into those spaces by raising the pressure in the work area.
Grainger is as good a place to start as any.
Hunter,
I'm sorry but I couldnt disagree more with ur post. u take a very simple task and complicate it 1000% risking contaminating every adjacent space. Negitive pressure is the only correct answer here.
".. and the CEO does not want to spend the cash."
If you ask me, this CEO should be fired if he's going to endanger his employees. He could also go to jail if he's trying to skirt OSHA safety standards.
Try a vacumn cleaner with a bypass motor.Simple mods to the tool hose and exhaust should work.
