Lost my Auto Pilot....
BigGrin
Yesterday I noticed my Raymarine Autopilot acting very strange. The course heading it was showing was very different from the actual heading shown on the Raymarine RL-70 Plotter. When I attempted to use the unit it would say "No Data" but still showed some ficticious heading. Also I noticed that the Boat Cursor on my Plotter Screen would show my vessel going in another direction. My tracks on the screen where however correct. I checked the Fluxgate for any metal objects and nothing new in that compartment. I have had this unit for 5 years without a problem. Any ideas? Thanks BigGrin
I had a similar problem a few months ago after my voltage bottomed out. I had
to reset the fluxgate compass, and "swing" the boat a few times. Now working fine.
If the track was correct, sounds like GPS had a fix.
I'd start checking the wiring to/from the compass. Sounds like youare missing power/data or both from the fluxgate.
GPS had a fix as it showed my track line perfectly and displayed the position correctly.
Do these fluxgate compassses go bad?
BigGrin
That Flux-gate compass is actually an Electronic circuit based on a Busy Chip.
The Board can go bad, but more than likely its the input's from the sensor, the voltage or the Ground that's the problem.
The first FG's had a sensor somewhere out on a wing tip, or on a boat it'd be up on a mast, in a car its out front or up over the windshield.
The actual Circuit board is somewhere else and the Readout may be in yet a differnt place.
Any communication problem with wires can be the source of a problem. But the board normally never dies.
Usually when somehting on the Board goes bad, the whole thing dont work. Like a light bulb.
All those Electronic devices are 'small signal' stuff that dont use much current. But its gotta be steady and reliable.
Cool deal. I always wanted to build one from a kit, but never found a use for it.
my Raymarine fluxgate went bad while still under warranty in 2006.
Now my Ray autopilot gives me a drivestop error, however there is no actual drivestop problem.
Big Grin we need to talk!!!!!
email pecomfgrb2rb2@gr5tgr5tyahoo.com
This sounds exactly like the problem I had/have with my Raymarine autopilot.
I have a S2G course computer and a St7001 autopilot.
The heading sensor would 'all of a sudden' deside that the heading I was on was actually 'over there' and the boat would steer up to 30 degress from where I wanted to go.
Changing the fluxgate had no effect.
What you can do is to unplug the internal gyro, not hard, pull cover and pull the yellow wired plug free.
Your course computer will default to a slow rudder speed and take forever to make course changes but see if the heading stays constant.
I wasted a lot of time with Raymarine technical support, spent lots of money finally bought a new computer so far so good.
BUMMER!!! Some poor bloke is going to have to STEER!! [:-sick]
