low oil pressure
Cutlass
After one hour at crusing speed port oil pressure drops. Changed the sensor and swapped gauges. Oil level OK. Tempurature normal. Engine sounds normal Same as Starbord engine. Could it be a bad ground?
Hopefully it's a bad connection...the alternative most likely requires removal and partial or full dismantling of the engine.
What make a model engine? Do you have an oil cooler? Does it have a thermostatic bypass etc. Not really enough information here.
I have a 1994 Carver Mariner with Crusader 350XL engines holly four barrel carbs. 270 hp 600 hours closed cooling. I have replaced the sending unit and swapped the gauges. Both engines have been running at 170 degrees F. Oil pressure on both engines 40 psi at start up. After about an hour the port engine start to drop. There are two oil pressure sensors per engine. One for the gauge (replaced) and one is the alarm. The alarm works but doesn't come on when the pressure drops. I know that when pressure goes down when resistance goes up and when pressure goes up resistance is down. I was thinking if I have an increase in resistance to ground when the engine temp goes up it could show a lower pressure. I was going to pull the sensor and see if the threads have contamination and see if there is an engine ground problem. I am planning on putting a mechanical gauge in but I would have to go for an hour boat ride. I was hoping that may be some one else has had a similar problem.
Oil pressure at idle ( and at any specific rpm) should drop as soon as the oil has warmed and thinned a bit. I think Crusader says ~10 psi for each 1000 rpm is ""sufficient"", though the lower end of that would give me excess stomach acid. . You don't mention how much the indicated gauge pressure drops . The fact the alarm does not sounds as it drops but apparently does during it's test phase should give you comfort OP is OK.
What oil weight and filter are you using and how old (months and engine hours) are they? ( Either straight SAE 30 or 15W-40 should be right I believe. Not 10W-40. Crusader suggests SAE 40 for above 80*F ambient. )
Have you needed to add any oil during the season on just that motor?
Level hasn't risen at all has it? No sheen in exhaust wake ?(Just ruling out oil dilution.)
The mechanical gauge check is a good idea but since that can be a PIA on some boats to rig up , I'd suggest perhaps just bypassing the existing OP sender ( not alarm switch) wire and running new test wire (with ring terminals) between the sender and gauge.
Keep in mind mechanical senders can be off too. An expert marine engine tech friend found a 10 psi difference between 2 of his spendy professional mechanical OP gauges when checking my old engines at same rpms and same oil temps.
When you changed the big acorn sender you didn't use Teflon tape , right? Those OP senders use 1 wire , so as you know clean & tight engine path to ground through the sender tapered threads is needed. Sometime those senders come with very little sealant on part of the threads but always say never use tape.
When you swapped gauges , was indicated pressure just the same?
You are correct that higher resistance in the sender circuit results in lower gauge reading. On the typical 0-80 psi gas engine USA gauge , 0 psi = ~ 240 ohms,40 psi =103 ohms, 80 psi = 33.5 ohms. So heat-increasing resistance in the wiring and connections is a good suspect if gauge reading is really below normal fully warmed up or cruising rpm range.
Thanks for the reply. I run the recommended SAE straight 40 weight. I usually change the oil and filters at 50 hours. I have had the boat since 1999 and have put a little over 400 hours on the boat. I have changed the oil and filters since I have had the problem. I use FRAM filters and have heard that filters can cause a problem with oil pressure. I have about 12 hours since the last change. But, the problem didn't go away. There has been a little change this year. Last year I took a 2 hour trip and the gauge would go down to 15 - 20 psi and then bounce to 0. No alarm. This week end I took a hour and a half trip and the pressure dropped down to 20 psi the would slowly go up to 30 psi. While I was in the marina I took the ring terminal off the sender and cleaned it and put a washer on both sides of the terminal with a lock washer. There was only a washer under the terminal. On the way back the pressure only dropped to 25 and work its way back up to 30 psi. The starboard engine stayed at 40 psi. I have never had to add oil but I did have little higher than normal oil before the last oil change and thought that my have been causing the problem. So I changed the oil filter and took out some oil to make sure it wasn't the oil filter or too much oil. Ran again with the same problem. My gut tells me it is a wiring issue but it is stressful to watch the oil pressure drop. Both engines drop a little at idle after a cruise. The oil pressure issue was the same after swapping gauges. I purchase a mechanical oil pressure gauge today and I hope that I can see the pressure drop at the slip. I hate to run the engine for over an hour at the slip. I may irritate everyone in the marina. I am not sure it will drop at idle. The only thing this year is I added coolant to the port engine. It was at the add line, but no oil.
Cutlass- That was a very good clarification, thanks. Now I can better understand your quite warranted concern seeing pressure drop way low and even to 0 though with no alarm. It will be very interesting to see what the mechanical gauge turns up .
One more thought , since the gauge reading is affected by the quality of the whole circuit , you might check voltage going to the gauge. If a loose or corroded positive supply wire connection is adding resistance which causes heat and yet more resistance over time , you could be chasing flutterbys at the gauge and sender . Since those gauge positives are daisy chained one to another , do any of the other gauges for that engine seem to have slightly odd readings when the OP decreases? Earlier you indicated no, but just thought I ask in light of the question about reliable positive supply.
If the engine cranks strong and starts easily, I'd guess the engine ground circuit back to the battery is sufficient.
Ok ,sorry, more than just one thought.... :D:
When you said you changed the OP acorn sender, was that with a new one, and which was rated for a 0-80 psi US gauge, not say 0-100 psi or higher rating?. Still that would not account for a drop to zero, so hopefully your tightening the terminal nut after adding the top washer is going to continue to prevent that kind of reading.
Did you try the temporary bypass jumper to rule out other possible chafe or corrosion resistance problems with just the sender wire and it's terminals?
If... the mechanical gauge doesn't reveal any glaring sender discrepancies, you might try a different filter than Fram , like Wix 51515 or NapaGold 1515 or AC, and/or a switch to 30 weight or 15W-40 oil to see if that makes any difference too, in case pressure differential in the filter from one side of the media to the other is causing the bypass valve to open. (My 2003 5.7L Crusaders spec 15W-40.)
Are the dipsticks on the 2 engines identical , at least as far as distance down to top "Full" level? If the low-OP engine had a shorter stick that could mean excess oil which can temporarily aerate and plummet pressure. ...Very long shot in your case.
Can you smell any gasoline odor on the low-OP engine's dipstick?
Thanks for all of your suggestions. I think the ground return from the engine is ok because my temperature sender indicates about the same as the starboard engine. If there was an engine ground issue all of my port gauges would have issues. The last run I made was in the Detroit River and the water temperatures aren't real high and both of my temp gauges read 170 degrees. My thermostats open at 180. I just replaced my impellers this spring. I am running a little on the cool side but maybe that's because of the cool water temps. My old impellers had very little wear. The sending unit was new and it shows the same problem that the old one did. All of the nuts are tight. When I pull the sender to put in the mechanical sender I plan on looking closely at the threads for contamination. I am also going to look and see if there is another in-line connector on the engine that may be where it can get hot. I haven't read voltages or put in a jumper. At this point, I would like to rule out the actual oil pressure. Hopefully, I can mount the mechanical gauge so that I can take a trip with it. If I truly have good pressure then I will look closer at the sender circuit. Because of this issue, I haven't used my boat much this year or last. I try something then it takes an hour to a hour and half for the issue to start. With the price of gas I usually want to go somewhere and not just ride around for 1.5 hours. But it looks like I might have to. I don't want to break down too far from home. Thanks for all of you help.
Johnnie
Thanks for all the ideas. I'll be trying out some the ideas and get back with the results.
Johnnie
If you want to save gas get a resistor that matches your normal reading and put it in place of the sensor. Turn the boat on without starting the engine, grab a cold one and sit on the bridge and watch the gauge for a couple of hours.
The oil filter has nothing to do with lowering oil pressure so don't worry about that.
Putting in a mechanical gauge is a very good idea. I have always installed mechanical gauges on ALL my motors (car and boat).
There are two oil ports where oil pressure is easily accessed. One is just above the oil filter mount. The easiest is on the back of the block just to port of the distributor. Because of it's vertical mounting position, it's the best port to put in a 'Tee' fitting to use it for mechanical and electrical sending unit.
How much is the oil pressure dropping? Oil pressure is the MOST important system on an engine. That's why an alarm and kill switch is included in the oiling system. Listen intently to the engine when the oil pressure drops. If you hear noise, immediately lower RPM and be ready to turn that engine off.
It's not a good idea to keep on taking trips until the oil pressure problem is corrected.
Maybe compare resistance of the 2 engines' OP circuits with one probe on the 12+v supply source to the gauge and the other to the threads on the removed but still-wired-up OP sender ?
Hmmm This is just a single-station gauge setup, yes? (Just checking, since a single station sender wired to 2 stations' gauges would read 1/2 normal. Gauges are the same for 1 or more stations. And I believe VDO OP senders may not make nice with other mfgrs' gauges. )
No dual station. My set up has a T with a can type sending unit for the gauge. It has a ring terminal on it (replaced sending unit). On the other side of the T is a mechanical switch for the low oil buzzer. I plan on taking the switch out and put in a mechanical oil pressure gauge. I will mount the mechanical gauge in the engine compartment. When I see bridge gauge drop I will have to go to the engine compartment to see the mechanical gauge. This way I can make a direct comparison with the two gauges mechanical vs resistive. I don't know the manufacture of the new sending unit but it reacted the same as the old sender. I have read that people have put in new sender and it was bad. That would be my luck. They are not that expensive and I would gladly replace it the third time if it solved the problem. At this point, all I want to know, is that I have good pressure. I have also been on automotive boards and have seen discussions about chevy 350s are known for lower oil pressure after warm up. As low as 10-15 psi. This engine has always ran 40 psi cold and about the same warm at 3200 rpm. Never, until lately, has it dropped down 15 - 20 at cruising speed. After dropping to 15-20 a cruising speed it will slow ease back up to 30 psi and then back down again. I had occasions last year where it bounced to 0 but no alarm. My starboard engine holds at 40 psi until idle after hot and then it will drop to 15 - 20. The maddening issue is that I don't see any of this until the engine is warmed up for about an hour. That's why my suspicion of a bad connection in the engine compartment where it gets hot (maybe this is wishful thinking when knowing the alternative may be pulling the engine). I will be sure to let everyone know what I find.
Johnnie
There is a oil plug just above the oil filter mount That's the return line from the filter. That oil port is one of the factory mount for one of the oil pressure sending units. The oiling system is so important that you could fill the filter with cement and the engine will happily continue circulating the oil. The oil filter mount has a bypass valve that has such a weak spring, it's virtually bypassing half the oil going to the filter during normal running.
Test run with mechanical gauge. First half hour with engines running 3200 rpms. Electrical gauge 40 psi, mechanical gauge 49 psi. At approximately 30 to 45 minutes, electrical gauge starts to drop to 30 psi, the mechanical gauge remains at 49 psi. 45 minutes to 60 minutes, electrical gauge drops to 15 to 20 psi, mechanical gauge stays at 49 psi. 60 to 90 minutes, electrical gauge drops to 10 psi and moves up and down ranging 10 to 15 psi, mechanical gauge stays at 49 psi. At 90 minutes slowed to 800 rpm. Electrical gauge 0 to 5 psi, mechanical gauge 32 psi.
I am very relieved that the true oil pressure is normal. Now I know I have an electrical problem. It's too hot to day to go into a hot engine compartment to check out the wiring. I will let everyone know what I find.
Johnnie
That's great news. Glad to hear your engine really is safe. Thanks for the update. Will you try the temporary replacement wire ?
