B
blouderback
Guest
Again, reading the latest Go Boating Magazine, they talk about how to change the oil in the lower unit. Do you warm the engine (and hence the lower unit) first?
They indicate that this may not be a good idea, because any water in the unit will mix with the oil and you won't be able to tell if there's water in it. I've always warmed the engine before changing, never giving a thought to the issue of mixing any water in the oil.
I usually check the lower unit oil as part of my routine when hooking up the boat to the tow vehicle before we go out for the day.
Does this seem like I'm doing things the right way?
