saleen8927
- Oct 1, 2006
- 23726
- 3
Hello all, I have a couple of questions regarding data for a Lowrance chartplotter (5200C). The unit takes Navionics Charts, Nauticpath Charts (which I believe is just a less expensive version of Navionics), or it can use Mapcreate software coupled with an SD or MMC memory card. My boating will be 95% Long Island Sound (CT side mostly), 5% Rhode Island area. I don't think I'll venture outside that area. What are the benefits of a Navionics card over the Mapcreate software? I like that routes/waypoints etc can be created with the software at home on the PC, then just plug in the card and go when on the boat (although that's not as important as chart detail). However, from what I can tell, there isn't as much detail with the software as on the Navionics cards. Also, I don't see that there are depths shown with the software. Does anyone have experience with either or both of these, and if so can you shed some light on the pros/cons of each? If having the software is just like having Navionics, just that I can change data and map area on my PC, I'd of course get that, but if it isn't going to be as detailed I'd go with the Navionics.
