Lowrance Technical Support?
rommer
First question, do they have any?
I'll answer that, no, none at all.
I spent good money on their new "HD" stuff and I'm very disappointed. I really tried to like the product but it locks up, has the most frustrating screw redraws I've ever seen and is LOADED with bugs.
One example that is important to me since we travel a lot is the search function when used to find local Tide stations, it's 100% useless. It brings up a list but when you select one the data shown is completely wrong. (If you select the tide station directly from the chart the data is correct.)
That's just one example. I called their "support" line and all they do is take a report of the problem. They don't even want your name or phone number. The woman said just go the the website and if they fix it they'll release a software update. 4 months and no updates, no callbacks and the unit still reboots 2 or 3 times a trip.
IMO, I'd avoid the HDS products till they get their ducks in a row since the product is buggy as hell and close to useless.
I agree, their support is very poor - I've been on hold with them waiting for someone to answer for over an hour. I've had to send a unit back 3 times, got it replaced, then was told it needed a new GPS module, which I purchased -and it still does not work!
Their units look nice and are great when they are working, but their support is terrible.
Simrad owns Lowrance. You can try to call Simrad and see where you get. You also need to work your way up the food chain, when you get connected tell the Call Center Rep you need to talk to an engineer for the particular product line, don't waste your time with a low level person reading from scripts. Lastly, tell them that your personal experience with their products is they don't work, are a waste of money and you plan to share that with all of your friends and acquaintances at the many various boating related functions you attend.
I went through the same crap of poor to nill support...There support is done on-line with FAQ...
This is very dissapointing. I'm considering a full HDS package this winter including broadband radar and maybe the side scan radar. This would be a pretty complex solution with alot of new functionality, but it soulds like a no go if they don't fix some bugs and get support up to speed.
MJK
Every marine/fishing website I visit has horror stories about Lowrance products and support. It just amazes me that people still flock to purchase their products. My last Lowrance was the LMS-350 which was a great unit but nothing since has been reported to be very reliable. There's too many other quality products on the market to take the risk with Lowrance.
Wow, I bought a LX-27C and it works just fine. It was a store model so they used the heck out of it. (maybe that was a good thing)
One concern I had: the transducer is a thru-hull Airmar which I bought from a Lowrance dealer. I hear a tick - tick noise. So I called Airmar and they said the unit is too strong for the transducer and will burnout. So I email Lowrance on how to turn down the power. Never got a response to the email. I called them on the phone - they never heard of such a thing! So I turned down the ping speed, hoping that will help(?)
I may be a little outdated but I don't think you can turn down the output. Adjusting the gain only adjusts the 'listening" sensitivity - not the transmit power.
Thanks Rommer. I have been considering the Lowrance HD package as a future purchase. No more. On the other hand, I have nothing but great things to say about Standard Horizon support.
I really have to wonder how a company like this can survive at all? The products can be confusing to use, buggy and they provide zero support.
Very surprising indeed.
I have a Lowrance HD in my 23'CC. Very bad mistake on my part. In my experience their customer service is simply a bad joke....
To expand my earlier comment, Lowrance said they never heard of their equipment burning out a transducer and told me to turn down the number of pings in order to save the transducer(?)
You want a nice system that you can depend on and is now N2K compliant? Look at Garmin's 4200 series plotters and all the N2K equipment. It is the easiest stuff I have ever used, it dead nuts accurate and you can upgrade it with an SD writer found on must laptops from their web-site. They are very responsive to complaints and bugs. Some of the big names in boating electronics have good things to say as well. You want to spend 3 times as much for slightly better performance go with Furuno otherwise Garmin 4200 or 5200 plotters and the NMEA2000 suite of components are unbeatable in my opinion. I have only had one bad problem it is with the GMR24HD Radar they finally replaced the unit after 3 trips back to the factory. In the mean time I installed the GMR18HD and have not changed it back yet.
