War Dept. lol
Well too bad that we won't be winter neighbors, but the War Dept. has a point – MacRay IS a long ways away from PA. Thanks for taking care of Carrie with a referral. As you saw, she’s not one to hold a grudge, so you’ll be welcome in the future.
People/boats CP left in packs this weekend. I was amazed. We had clear blue skies, calm wind, warm dry air, and all these people fired up and headed for the hoists. I couldn’t do it! If I were them, I’d call the marina and postpone the haul-out.
I cruised out to the lake in my neighbor’s aft cabin. We came back to the fuel dock and saw Ramsport cruise by with Dogdaze and co. as passengers. “The Dog House” looked so good that my neighbor took pictures. An hour or two later, Dog Daze cruised by with Ramsport and co. as passengers. (it looked good too)
Haul out when it’s 78 degrees? No effin way!
No matter where/how your store, moisture is the enemy. You probably have Attwood sumps? If so, clean ‘em out and dry them out. Take the lids off, and then twist off the pump motor. The base comes out with a single screw. Removing the base and the grommet will release the check valve, letting the water trapped in the hose backfill into the box. Find the check valve, which is a small rubber disk that will have be laying somewhere in the box. After cleaning the box, pump, strainer etc., suck out all the water with a shop vac. The check valve goes back into the hose inlet, notch down. Re-assemble the pump and strainer, but leave the lids off until spring.
Pull the boards up from the salon holds and sit them upright to allow air into the holds. (do this last – I don’t want to hear about you stepping into a hold and breaking your foot per my advice!)
Drop some vegetable oil into the heads and flush, but make sure the heads are dry before you leave. I don’t use holding tank treatment (don’t have to, knock on wood), but this is the time to dump some in just in case.
If you’ve run the A/C recently, use the vac to suck up any condensate in the pans.
Defrost and clean the fridge, and unless you’re 100% sure that it’s 100% dry, prop the door open.
Replace the central vacuum bag.
Make sure the galley is clean and empty – heated warehouses are welcoming places to rodents.
Buy a box of scented drier sheets and put the all over the interior – in drawers, cupboards etc. Rumor has it that insects and spiders dislike the fragrance. Whether or not that’s true, the War Dept will appreciate it in the spring when the boat smells “April fresh” instead of “10 year old boat”.
If I were you, I’d also give the fresh water system some “red pop”. I know that most people will tell you that you’re defeating one of the great benefits of indoor heated storage, but I’ve found that it discourages growth and also helps you make sure the system is thoroughly flushed come spring. In fact, I’ve also found that it helps break down calcification, so for $5 now and some extra rinses in the spring, it’s good peace of mind.
Open as many spaces as you can. Leave head doors OPEN, pull the sofa cushions out to allow air underneath them. Get as much of the “soft goods” off the boat as possible: take the blankets, sheets, pillows etc. home. If you don’t want to take it home, then use the vacuum bags, ie: “space bags” that form a strong seal.
Open the deck hatches just enough to allow the handle to go back to the lock position while still being in groves of the flange. This will allow the rubber seals to rebound a little and it lets some air circulate while hopefully not encouraging rodents or dirt.
Remove the batteries from your remote controls.
Give the power hatch in the windshield a bump or two – same theory: let those rubber seals breathe a little.
If you’ve anchored recently or stuffed the bow in seas, pull ALL the rode out and let it dry, then pull it back in.
I take the door off the icemaker. All you have to do is take the top screw out of the hinge and the door lifts off. If you have a way to prop the door open, you can do so.
If you have any doubt about possible drains on the batteries, disconnect them. Make sure they have water and are fully charged before you leave.
Use the shop vac to dry the bilge if necessary.
I still believe in an end-of-season oil change, but the engine discussion could be a whole other thread.
