Main Bilge Pump Hose
PortHoleDiver
Hi, all this is my first post since joining and becoming an anchor member. I purchased a 1985 SeaRay 300Sedan Bridge a year ago. The main bilge pump in the engine room is in a recessed area where both engines and the water from the stuffing boxes can leak into. Question: the hose is connected to a 1500 rule bilge pump and it makes a loop and then traverses to the starboard side for discharge. However when the pump shuts off water in the hose drains back to the bilge and the bilge never gets dry. and then the eng room sweats etc. Is it recommended to install a back flow valve in this hose to stop this? I have heard different opinions but they were from questionable individuals. I really want to know what you guys think.
That's normal. The best thing you can do is get the hose higher than the discharge as quick as you can because the water that come back is from the part of the hose that is lower than the discharge. Check valves are not recommended, it could clog and it will slow output.
I have check valves on all my pumps. But you may have to increase the size of the pump to overcome the increased head pressure.
You could leave the pump as is and add a second pump (good redundancy) with a check valve to get out the balance of bilge water –
bilge pumps never dry out the bilge... i would NEVER use check valves on bilge pumps, it's not a matter of if but when they will jam. most surveyors will tell you the same thing...
if you reall want a dryer bilge, then add a smaller pump with a check valve, just to suck the last gallon... butg no check valve in your primary bilge pumps
It is recommended that you NOT have a check valve. They a) restrict flow and b) can easily fail/clog.
Bilge pumps do not pump the bilge dry. They remove "bulk water". There is always a residue.
Adding a "finish pump" as described above will remove much of what remains, but it is -still- unlikely to actually dry the bilge. Not worth it, in my opinion.
I agree , no check valves on the bilge pumps. That's a disaster waiting to happen. Why not find out where the leaks are coming from and correct that problem. Since I switched to GFO packing, my stuffing boxes don't leak and my bvilge is dry.
You could add a "finish pump" as Radioactive mentions, and install a check valve in that since it's not crucial if it clogs, but installing check valves on the primary pumps' hoses is really risking clog when you most need it to remain clear.
What do you mean "it makes a loop"?? The hose should be as direct as possible to the hull outlet to minimize drainback, with the somewhat rare exception of a possible small upwards loop at the outlet to lessen wave ingress. The longer the hose , the more residual bilgewater. The exception to THAT would be having the hose go as near as possible straight up from the pump to a height just a bit above the hull outlet , then have a secured no-dip run of hose slightly pitched down right to the outlet.The pump "head" would be virtually identical, but much less water would drain back. Few boats have the space for that configuration though.
if you look are where many builders put the thru hulls, often close to water line, you really want an 18" riser loop on your bilge pump hoses !
