Mainship Trawler 400
pgilbert
The wife and I looked at a new one this week. What a nice boat. Lots of great features (wife like the washer/dryer combo). All electronic instrumentation and throttle/shifters. Extremely smooth shifting. All digitial gauges with the excption of the fuel. Very roomy. Built in bar-b-que grill on the bridge. Variety of power options. The sales guy made a comment that with all the electronic, you had to run the generator while cruising. It didn't make any sense to me. While running, the batteries are charging so why run the generator....unless he was talking about sterring from the cabin versus bridge.
My wife only saw one thing she did not like. The electrical panel was in the salon but there was no door covering it. Her concern was kids (or grownups) flipping switches inadvertently.
Bottom Line - nice boat. Would love to buy one used in about 4 years.
What are your thoughts on this boat?
I'd wager that, if you made a door on the panel a condition of purchase, you'd find one there pretty quickly.
We have a Mainship 390, and we agree that they are great boats. As far as running the genny while underway, we have a built in inverter which most owners of these type boats usually install. The inverter will take care of all your 110v loads such as freezer, fridge, tv and microwave. Really no need to run the genny outside of charging the batteries, running the AC and cooking. The hot water is also heated underway by the engine coolant.
We have never had anyone flipping switches on the power panel, it is about 4' off the floor, so basically out of reach of the rugrats.
Good luck if you decide to buy, there is a pretty active group of Mainship owners on Yahoo Groups.
-Ron
sorry but if you're judging a boat by the washer/dryer, electronic engine controls and built in BBQ.... you may be asking to be disapointed... i'd be a little concerned about a builder who tries to save a few bucks and not have a door on the electrical panel when it's in a very easy to trip location. what else have they cut corner on ?
that said, it's a pretty nice boat although in that size range i much prefer the layout of the beneteau Swift Trawler 42
in the mainship, when sitting down you have the fridge in your face and the galley... the beneteau, and others and a better layout in my opinion...
check out the Camano 41 if you don't need a second stateroom.
There seems to be more & more 'sedan' trawlers available again. Marine Trader, Island Gypsy, GB & others produced them in the 80s.
The Mainship is a good bang for the buck boat. It is not top end but not a POS that will be hard to sell later either.
Judging a boat by wheter it has digital or analog guages, the fabric colour or how many flat screen TVs it has is no measure of construction quality.
Start lifting hatches, opening cuboards & actually stick your head inside to see how it is all put together in places the eye is not normally going to see. Can the seacocks be reached easily? Try, don't just look. Can you reach parts of the engine that are likely to need attention? Get in there & try to reach, don't just look.
I agree that the Camano is a nice boat but it should not be compared to a Mainship. The Beneteau? Well, it is French. Besides that, I 'boatsat' a Benateau yacht a few years ago. The build quality was not very impressive at all for a number of reasons.
Originally posted by pgilbert
Dealer said You have to run genny when all electronics are on)
My 2004 Carver 444 had a problem with not being able to keep batteries charged if you ran all the electronics. It would kick breakers sound warnings, was a real pain. Carver told me to start the genny when i leave port and turn it off when i hook to shore power, then no low charge issues.
I traded that boat for electrical and other reasons after a single season of use. I now have a 2005 Meridian 411 and have not looked back.
John D.
I spent a lot of time looking at MainShip 34 and 40. I find them to be roomy maybe easy to handle for a couple and can be bought for a fairly low in price. 34 $220 K 40 $300K. At that price range there is not much that offers trawler style and semi-displacement speeds. The 34 is (just 2 feet shorter same beam)very close to the 40 in over all size and may be the best buy. Check the dim's Mainship below. Walstrom Marine in Cheboygan,Mi is a dealer and they have a 34 Trawler well setup you can buy for less then $220K. That is not a bad way to get into a new boat with a lot of features. It sure is not a Tiara, but it is a lot of bang for the buck. They do seem to roll more at the dock then other boats I have been on, but owners seem to love them so they must be doing something right.
John d
Link to ad $219900 asking
http://www.walstrom.com/newyachts/mainship-34-2005.html
34 trawler
SPECIFICATIONS
All data is approximate and subject to change without notice.
Length Overall: 36'1" 11.00 m
Length Less Pulpit: 34'0" 10.36 m
Beam: 14'2" 4.32 m
Draft: 3'3" 0.99 m
Headroom: 6'4" 1.93 m
Clearance Height – Trawler/Flybridge (Air Draft): 15'0" 4.57 m
Clearance Height – Hardtop (Air Draft): TBD TBD
Sleeping Capacity: 4
Displacement: 20,000 lbs 9,080 kg
Fuel Capacity: 250 gal 946 l
Water Capacity: 70 gal 265 l
Holding Tank: 34 gal 129 l
Available Power:
Single Diesels from 315 hp to 380 hp
Twin Diesel – 240 hp
40 Trawler
SPECIFICATIONS
Length Overall: 41'4" 12.60 m
Length Less Pulpit: 36'0" 11.20 m
Beam: 14'2" 4.32 m
Draft: 3'8" 1.12 m
Headroom: 6'6" 1.98 m
Clearance Height (Air Draft): 19'2" 5.84 m
Sleeping Capacity: 6
Displacement: 24,000 lbs 10,896 kg
Fuel Capacity: 300 gal 1,136 l
Water Capacity: 130 gal 492 l
Holding Tank: 47 gal 178 l
Available Power:
Single Diesels from 370 hp to 440 hp
Twin Diesels – 240 hp each
VB... i'm pretty sure that like most beneteaus sold here that they are built in the US... and as you know too well, you can't judge a 2006 boats based on what the builder used to build a few years back.
regarding having to run the genset, something isn't right... typical electronics shoudln't require a lot of power compared to lights, pumps, etc... i can't imagine a builder delivering boats where the alternators woudln't be able to supply enough power ! breakers shoudl not be popping because you're pulling too much DC out of the batteries...
once the engines are off though, that's another story. the number of batteries most boats come with is a joke and most people end up having to run the genset 24/7. batteries are cheap... but so are bilge pumps and we know that most boats are seriously lacking pumping capacity as well.
While i liked the 34 and its derivatives the low headroom over the forward part of the V berth was a turn off. You cant sit up to read and if not careful will bang your head getting up.
They are decent boats IMO but are semi planing hulls and with low power are not trawlers but simply low powered boats. Probably the type should be called crawlers instead. This is not a criticisim of the boat at all just the marketing BS they seem to feel necessary to sell a good boat.
That you noticed rolling is a combination of hard chines, which true trawlers avoid and a lot of weight aloft on some models
If you need a boat with 2 heads 2 feet from one another, perhaps the Beneteau is the boat for you. I was unimpressed with the interior several years ago, and reconfirmed my dislike for the setup at the boat show last weekend. Sure they are appealing from the exterior, but the salon seems a bit narrow, and there's a galley crammed into the port forward corner where a nice double passenger seat could placed. I guess the second stateroom to starboard down forward is what some want, but it could be setup as a sofa/bunk as well, or a lower galley. As far as 2 heads taking up the whole portside of an already narrow "fast trawler" forward hull section, my best guess is they removed a bidet and rather than reconfigure the boat for the American market, they simply replaced the bidet with a second head. Hey the plumbing was already there right?
PascalG, maybe I was expecting too much on something called a 'yacht'. I have to admit the only other sailing 'yacht' in that size that I have had a real good look around was an early 80s Swan. Comparing the Benateau to the Swan is like Comparing a Meridian to a Flemming I guess. Not fair.
Back on topic, in that blurrey world that boat types live there are few true 'pocket' trawlers i.e. 30' or less, single diesel & having a true displacement hull. There are a number of 'almost theres'.
I'd consider my old 1986 Albin 27 a 'pocket' trawler.
This boat slept 4 adults very easily, had a 'close the door' head, 50 gal fresh water, had a semi displacement hull which, through a designed 'hook' in the bottom, planed in it's own quirky way with only a 100hp diesel.
Albin also produced a 34 'trawler' in the late 80s. This looks something like a 27 aft cabin but on steroids. It has a head in the aft cabin as well as fwd. The production run was short. As practical as they were, they are butt ugly. They can be found on places like boats.com for $60K or so. Very good for a 34' boat. Most have the Cummins 5.9 210hp.
From the 34 hull came the very successful 32+2 Command Bridge, a totally different boat inside the hull but retaining many of the 34s cruising ammenities like over 100gal of fresh water.
Over 300hp gives this boat some giddy up & go but in the cabin it is very much a comphy cruiser for 2 which can honestly sleep 5 adults if needed.
GW, any boat in that size range with a walk around is going to feel narrow inside, that's the nature of the beast. it's all a matter of personal preference for the most part but if you put the galley long one side, with a tall fridge, i think it makes it even more narrow... and if i want to relax after dinner, the last thing i want to see is dirty galley in my face ! :-) i'll trade the forward passenger seat for the the galley out of the way, especially with a flybridge. but again, it's all compromise and personal preferences.
i agree about having two heads, it's a waste of space on a 40 footer...
VB, yes.. a Swan isnt' jsut a boat.. it's a SWAN !
