Manual Head Leak
boatboy256
Hi All
On my Chaparral 240 I noticed a leak last week,just started using it,the large hose at the bottom was leaking,clamps were tight ,loosened them up and moved ths hose around and retightened clamps and it stopped leaking,last night went to visit the boat and saw a little leaking at base of head,appeears to be water that was sitting in the bowl,a little yellow from the deoderent I put in after last time was used,,ran my fingers around all the hose connections and were dry,is there a way for water to leak out the base were it bolts to floor?Also noticed carpet wetness in frt of entry to cabin in frt if the head compartment.The head seems to work fine,Thanks in advance for any replies.
