marina vs. on hook
mrknowitall
I am considering a move. I like the idea of keeping by boat, 33' Chris Craft Coho fly bridge 1974, in front of my house May - Sept. We live on a 3 mile by 8 mile bay, our home is tucked in behind a point and fairly well protected. My neighbor has a dock and keeps his 30'+ sail boat at his dock for the same date range then moves it to the marina. In the fall I would keep it on the hard at a friends boat yard. I am trying to think through all the options before I take the plunge. I waited about 2 years for a 40' slip and don't want to leave and then get back in line. I figure I need to set it up with solar power for my batteries. My ground tackle should do, CQR and 100' chain. I think a wash down fresh water tank should be added. Mast light/anchor light configuration will be looked at. I welcome all ideas and input. I figure I will save money and have it closer to me and may use it more. I haul once a year anyway.
I guess you do not have a dock? So you would anchor [moor] the boat near your house? Personally I'd prefer to have my boat at a dock. Can you rent some space at your neighbor's dock?
I dont understand your question however A mooring is a PITA IMO
PITA? not sure I understand your response. I'll try to give more info... My neighbor's dock is not configured in a manner that would accommodate my Chris Craft, he has been cool about us leaving a tender tied off on his dock, my wife pays him in fresh caught crab. I do have a easy launch from my beach. I use a honda four wheeler to launch a hard bottom tender. Very easy access in all conditions, in fact I often take the HB to the marina because it's faster than diving around the bay, 10 miles one way. My reason for the post is to get input about leaving a boat on it's own anchor for 5 months. My top of mind considerations are, fresh water, fueling plan, anchor light, solar panels, proper anchor and rode. Are there other factors or considerations that I am missing?
Thank you for the reply. I feel,PITA, whenever I use public launch ramp. I just keep boating anyway... it's an addiction that can't be satisfied.
on a mooring you cant use shore power to charge batteries if the bilge pump uses them up and it is difficult to check on status. nevertheless I have kept boats on their own anchors, including one hurricane, for the summer season for many years but you need to be sure the boat is in good enough condition to be left really unattended.
I think that is why he is planning to use a solar charger.....
sorry Liz but no solar charger will keep up with a bilge pump.
Well not bad idea having the boat out your back
door.
Weather is a big thing when keeping boat anchored
you must make sure you have a good mooring so when
the weather is nasty it will stay put.
There is alot of PITA things about leaving a boat
on a mooring compared to having it at a slip in a
marina where it will be much more secure.
I like to sleep all night long and not worry if my
boat is OK,I know my wife doesn't sleep well when
we are on the hook in a cove for an over nighter.
Thanks for the input. Tonight I set my 14' fishing boat out front tonight to see if it's a PITA; maybe leave it out a few weeks. One consideration is I have a friend with a boat yard and all the equipment to move the boat in the fall. Over the last few years I have found I don't use or want a boat in the water from Oct through April. My home has pretty good protection for a safe mooring in the months I am considering.
When the boat is at a marina you have a place to go, different people to socialize with, less worrys about damage and generally more piece of mind.
A boat on a mooring is a PITA. You have to unload into your transfer craft then load onto the boat, you make a lot more trips than you can think are necessary then have to go back again.
The only possible reason to be on a mooring is to save a few bucks. One break in takes care of that.
Yup, going back and forth with stuff is a booger.
If you moor, you need a good permanant mooring bit. An old 327 Chevvy motor block will almost do the trick. Two of them would be better. You'd be surprised what the wind can drag. One of those great big floats to keep the Bit in sight.
Another PITA part is keeping the Generator running. You'd have to plumb the fuel supply into your main tanks to make sure that thing wont run out of fuel.
Then you put a 110 Light up somewhere visible from shore to tell you your Generator is still working.
Maybe, it its not too far offshore, you could run a long extension cable from the house out to the Mooring Bit?
I can understand your desire to have the boat on a mooring at your house for the reasons you have given. Those being having the boat immediately available for increased use and the advantage of less expense. However, as others have mentioned there are some downsides also.
Refering back to your original post about losing the slip that you waited two years to get, my suggestion for you is do both this year. Keep your slip this year, so you don't lose it and have to get in a wait list again. Set up a mooring and keep your boat at your house for a good bit of the summer.
That way you can see if the advantages of mooring are worth the downsides, without losing your slip. Also, that way if on July 1 you realize it truly is a PITA, then you can motor your boat back to the slip you still have. Also, I would suspect if there is a two year waiting list on slips at the marina, if mooring is working well for you, I bet you could sublet that slip for the rest of the year and recoup some expense. Then next summer, if the mooring at your house was good for you, you can give up the slip without concern.
Just my opinion and what I would do,
Gary
There's not too much sun during a three day rain event.
What will keep your batteries charged to keep all around light and those bilge pumps going?
What happens when a bilge pump float switch sticks and that pump drains the batteries and then burns itself up?
Do the risks outweigh the reward?
I live in the PNW and have kept my 50 ft on my mooring bouy the past 2 seasons for summertime. Everything works well and it really is not that much of a PITA, you get used to rowing/kayak/etc to your boat and fire up the genset for a bit if you need to charge the batteries, I think I would like to get solar this year. It sure beats paying the PITA moorage fees for a few months, now I can apply that towards fuel. I have 2 neighbors (60 foot and 40 foot) who leave their boats on their buoy year round which I would never do. I don't like the idea of moisture inside the boat.
" sorry Liz but no solar charger will keep up with a bilge pump."
It depends on the solar charger, the batteries, and the bilge pump; and of course the $$$$ you're willing to spend. Unless the boat has some serious leaks, I see no problem.
There are many boats that are left on moorings
all season long and some love and some hate and the ones that hate it are on a waiting list for
a long time some times years.
I would not give up that slip until you know for
sure that the mooring is good for,one bad damage
will wipe away the savings of no slip fee.
If allowed maybe sublease the slip the first year
or so,I repeat don't give up the slip if there is
a long waiting least to get it back.
I wonder how confidant mr.K will feel about the prospects of his 34 yo boat at a mooring during the next big storm. Some times you have no choice and as I said I moored boats all summer for years with no problem, except once when one of them almost sank due to rain and inexperience on my part. It is hard to check up on a moored boat so it isn’t done as often as it would be if it were at a dock.
