Marine Carpet
jimraab
Flutterby,
You had mentioned in a recent post that you replaced your cockpit carpet with standard commercial grade carpet and that it is holding up just fine. What type of backing does it have and when you clean it do you soak it fully with the hose?
Thank you!
Hi Jim
The carpet just has the typical weave backing. It is high quality commercial carpet. I do NOT use a hose/soak it clean. I have only cleaned it by taking it home and using my home carpet cleaner. It comes out looking new every time. My carpet is protected from the elements and sun by the canvas enclosure.
Good luck!
