Marine Radar
loun
My "new" boat came with a Raytheon chartplotter and RADAR. What is the best way to learn how to interpret the RADAR?
Lou
practice practice practice...
practice during the day, with good visibility and you'll quickly learn how to interpret the targets and how to get the settings right.
Ditto, ditto, ditto..., and of course read & refer to the manual to better understand setup that may have been done or needed and what each control addresses and what each data element on the screen represents. If you don't have the manual, try here: http://www.raymarine.com/Default.aspx?site=1§ion=3&page=166 . With older Raytheons, even if auto-tune is available , manual tuning and control tweaking is generally much more effective at getting best target returns.
FWIW-I've never watched one, but there is a company called Bennett Marine Video that makes instructional videos that may cover your electronics.
If the chartplotter is actually just a chip-reading control head that toggle-displays on, say, an R20XX radar screen, don't spend much time dealing with the "chartplotter".
There are several very good books on marine radar. Along with the Starpath Radar Trainer DVD.
Radar For Mariners
by David Burch
Using Radar
by Robert Avis
Radar Book: Effective Navigation & Collision Avoidance
by Kevin Monahan
"Everything you ever wanted to know about maritime radar, but were afraid to ask" aka: "The Radar Navigation and Maneuvering Board Manual", from NAVCEN.
Likely far more than you were asking for, but the price is correct... Free.
See also, on the same site, "The American Practical Navigator", by Bowditch. Same price.
Of course, for basic details, the mfgr User Manual should be useful.
You didn't specify the model or age, but some Raymarine/Raytheon User Manuals can be found here.
Radar is a VERY useful tool that can save your life; but if you don't know what you're doing it can kill you.
Call an outfit like Sea School, they have classes in radar that will cover the basics. Then Practice, Practice, Practice.
Use it in CLEAR weather so you can learn to correlate what it tells you with what you see. If you wait till the weather shuts down it's too late.
"What is the best way to learn how to interpret the RADAR?" -- loun
As stmbtwle sez: Practice...
Use it all of the time, good weather and bad, light or dark. Keep trying to get the best "picture" you can. Become accustomed to how the Radar displays objects in visual range. Radar "sees" differently than the Mark One Eyeball.
Note how different things change over time. ie: a barge is a huge flat target. "face on ( at 90 deg ) it will usually present a huge blob. But at an angle it might present a very poor return. Birds can show up better than beaches. ( Sometimes you find the beach because the birds are sitting on it... then the birds take flight and the "beach" disappears! ) Just keep using it, esp in good conditions, and compare the radar image to the visual. Practice. As stated above, often manual time will provide better results than auto. Practice tuning. Observe the difference as you tune it, to see how each filter, or modification alters the display. It is actually not all that difficult to get and use a radar moderately well. Getting real good does require a bit of effort and a bit of reading, but the results are worth it.
All of this practice will make a world of difference the first ( and following ) time you use it because it is necessary, and the familiarity with the controls means you won't be "head in the cockpit" all the time.
Which, by the way, is important. Radar is but one tool in the group of tools that you should be using. Keep it in your "scan loop", but don't get fixated. Be sure to keep you eyes actually out the windshield and looking at reality most of the time... check your GPS-plotter, radar, instruments, then look outward again.
Some on this site feel that it is necessary to only use radar "when required", as they feel they understand it well enough. I take a different approach, and use it all of the time. Period. Even in wonderful conditions, radar can call my attention to objects that are visible, but that I may have missed or dismissed. Plus, it means that I never need to alter my "scan loop", nor do I not have the radar up, running and tuned if it becomes necessary.
One other item: All of your electronics should be operated periodically. Having them warm up to operating temp foe a while is good for them and tends to keep them drier, which improves reliability/longevity. Letting electronics sit and wait "for just that critical moment" may find that the equipment has corroded while it sat... Use your equipment. You paid for it, get your money's worth out of it.
