Hi all, I have a 30' Sea Ray and last year winterized fresh water tank by emptying and adding gallon of RV pop and running it through.
This year I flushed it out and filled tank ran it through and filled it again. After a month of non use it now smells like rotten eggs.
If I emptied this 30 gallon tank and refilled and adding a pint of bleach and following Vic procedure will this fix "my" problem?
This is an outline of Vic's procedure for recommissioning a water tank in the sticky:
1. Use a solution of 1 pint Purex or Clorox bleach to 25 gallons of water). With tank empty, pour chlorine solution into tank.
2. Complete filling of tank with fresh water. Open each faucet and drain cock until air has been released and the entire system is filled. Do not turn off the pump; it must remain on to keep the system pressurized and the solution in the lines
3. Allow to stand for at least three hours, but no longer than 24 hours.
4. Drain through every faucet on the boat (and if you haven't done this in a while, it's a good idea to remove any diffusion screens from the faucets, because what's likely to come out will clog them). Fill the tank again with fresh water only, drain again through every faucet on the boat.
