Maryland Registration?
bmetros
I purchased my boat in PA but am registering it in MD. I received via mail, 2 lighthouse stickers and a registration card. I guess I'm supposed to have new numbers made and apply them to the boat. Are my new numbers the "Boat NO." listed on the registration card? Will I receive a new title for the boat?
Your registration number should be MD followed by 4 numbers followed by two letters. That is what you display on your boat. The lighthouse sticker is generally displayed after the number.
The title should follow in a couple weeks.
By the way - Congratulations!
Bill, is this a new boat or older boat purchased? I remember Maryland registering my old boats with the boat's previous numbers which came with the boat...(the boat's numbers transfer with the boat, to the new owner and new registration)You mentioned new numbers were to be installed.
CarterCrew is correct with the application.
Congratulations!
Everything said above is correct. I'll only add that if the boat is USCG doucmented you do not apply the MD numbers to the hull.
Well Mike just entered an entirely new set of criteria in here. [:-magnify]
If indeed you documented your boat, there are different stickers involved as well. It's called a validation sticker not a registration sticker and it looks different - I am having a brain freeze right now and can't recall what mine look like.
You also do not get a title in that case, your USCG documentation certificate takes the place of a state title.
Confused yet?:D
...I thought about that a few minutes after posting. My boat is documented with MD home port and no numbers as well.
You don't have to have them made per se, you just buy the letters/numbers you need from a marine supply store and put them on.
When you put them on, leave a full letter width between letters and numbers, e.g., "MD_1234_AB"
You can also get the vinyl numbers at any hardware store, Wally-Mart, etc.
Thank's All. She's an older boat, but new to me.
If Spring doesn't get here soon I'm gonna run out of closet space for all my new purchases.
