Blouder, I have always found the least amount of time you spend determining where your tabs are is the safest situation. Tab adjustments historically make you "Look down" even if you don't realize it. Ignition resets return the tabs to full up when you turn the engine off. Next time you use the boat you know exactly where they are and adjust easily from there. Indicators(I use lighted ones" leaves nothing to the imagination while trimming on the fly. In addition, some boats simply list to port or starboard a bit normally(gear, fuel, water tank etc impact this) I have always found my sweet spot on the tabs and go right to those on the indicators. If passengers, gear, seas or weather impact my sweet spot, the indicators make the adjustments quick and safer. Again, not seeing where there are but "feeling" your tabs takes longer and creates a normal "look down" by the operator.
