Mercruiser 470 Circulating Pump Seals
gunks
1987 Mercruiser 4 cylinder FWC - leaks antifreeze out of the weep hole on the circulating pump .( pump is part of the timing chain / front cover and not replacable ) I replaced the 2 camshaft seals and installed Redi-Sleeves over the scores on the camshaft. Still leaks , though not quite as much . Any ideas ?
