When I set my timing on my Mercruiser 305 it starts fine and idles good but when I accelerate it backfires through the carb. I short out the wire to disable the electronic ignition advance and set it at 10 degrees BTDC. If I fine tune the timing by ear it runs great but then it starts hard, acts like something is binding up although I believe this is just the timing too advanced causing it to fire at the wrong time. A little history, I rebuilt the engine, cam and crank marks were lined up, I brought #1 up to TDC and installed the distributor so that the rotor lined up with the #1 spark plug. I forgot to mark the original position of the distributor but by turning the distributor I wouldn't think that if I were of a tooth either way it should make a difference. Am I wrong? I've looked all over for info on exactly the position the distributor should be placed but can't find any thing. Also, my gas is clean, no water or gook. I've been fighting this for about a year!
