Mercruiser motor keeps stalling
fredpacc
Hi All,
I have twin 1986, 5.7 liters mercruisers. Both engines never gave me a bit of trouble in 12 years. 3 weeks ago while briging them up to cruise speed, the port engine just slowed up and died. It started right up, but the same thing happened several times. I thought it may be a dirty fuel filter, so I changed both - no help. Since then here are the things I have done. Replaced coil, checked plugs, replaced distributor cap,rotor, sensor, I ran engine off fuel tank that the good engine runs off. It seems to happen around 2600 RPMs, after being at that speed for a minute. The motors run fine at 2200 rpm so I always make it back. All gauges read normal,i.e temp, batt, oil press & volt. Any help would be greatly appreciated, I really would like to go off shore fishing! - thanks - Fred
sounds like you might have a spark advance probleem, maby a vacum advance poblem caused by a leaking vacum hose. this is a place to start. you can pull the cap off the dist. and see if there is any rust on the advance springs in the distribertor. if the slingers are froze up with rust they cant advance when you rev. up the engine and it will do alsorts of crazy things and one of them is stall when powering up.
THanks guys for responding, however I have electronic ignition so there is no vacuum or springs. If you come up with anything else, please let me know. It does sound like a fuel problem - Fred
Do you think the fuel pump could run effectively at 2200RPM but fail at higher RPM's? There is a sight tube that runs from the fuel pump to the carburator, if it fills with fuel it indicates the diaphram has failed. It removed it and it is clean, so I don't think the diaphram is compromised. Let me know what you think - Fred
Fred,
Have you checked the engine codes for a sensor fault? I remember reading that the Mercruiser ECM changes modes at about 2800 rpm which is about where you're getting the problem. If you have a Seloc manual, it might have the info.
Fred, are you attempting to be at/near idle when they stall? Have you changed your shift cables in the 12 years you've had it?
When we first got our boat, the first trip out, when we came back to idle/neutral, it would stall.. turned out to be shift cable/neutral switch turning them off.. was also difficult to dock when the engines kept stalling.
We had the drives serviced and they required new shift cables (drive end cables) which resolved the stalling problem. Naturally, the boat needs to be out of the water and the drives need to come off to replace them.
Not sure if this is your issue or not, but I wanted to mention it.
Regards,
Originally posted by divedaddy
My guess would be fuel pump.
Reason I suggested fuel pump is about two months ago I had one fail - it behaved much like you describe. I have carbed 7.4L Mercs. But, there was fuel in the sight tube. Push the throttles up, just as the engines crossed ~3000 RPM the port engine would fade to ~2000 RPM. Could run forever at 2000. Pull it back to idle for a few minutes and could do it again and gain.
On some of the earlier Merc models with EFI, there was a "power reduction mode" that could be triggered by any one of several sensors. Here's a description form a Merc manual
POWER REDUCTION MODE
(1996 AND OLDER MODELS)
The ECM will go into power reduction mode when the
following conditions are met:
1. Low oil pressure
2. Engine overheat
3. Low I/O fluid level (MCM)
4. High transmission temperature (MIE)
The ECM recognizes change of state in a discrete
switch input that identifies an abnormal condition
that may affect proper drive train operation.
As an engine protection feature, power reduction
mode allows normal fuel injection up to 2800 RPM.
Above 2800 RPM, fuel delivery is limited to half of
the injectors until RPM lowers to 1200 RPM when normal
fuel injection resumes.
This feature maintains maneuverability of the vessel while
removing the possibility of high RPM operation until the problem is corrected.
If you have electronic fuel injection you should probably check the ECM first.
I have a 98 merc. that had a stalling problem too. fuel pump works and would stall unexpectedly at any rpm. Changed the fuel pump relay. works well so far and an inexpensive fix if thats the culprit.
My guess is the Tank vent for that engine is partially plugged.
One more odd thing is the line coming out of the tank may be cracked (or someting) and will begin to suck in air at that high rate of fuel usage.
