bomguthrie
- Nov 22, 2013
- 33514
- 9
I have some corrosion behind where the label is for the outdrive. It almost looks like there were originally two holes and that been corroded out more.
My mechanic says this is the sign of big trouble and the engine must be pulled, along with the outdrive and the assembly replaced.
He also said this could be causing some leakage in to the bilge.
Seems like I would just remove the corrosion, use some corrosion inhibitor, then seal up with 5200.
https://dl.dropboxusercontent.com/u/71616959/sundancer - stern drive.JPG
Thoughts, experiences?
Thanks, Mark
St. Petersburg FL
Searay Sundancer 280
Twin 4.3 Mercruisers I/Os
Thanks, Mark
St. Petersburg FL
