mercruiser timing specs
peteyo
Hi. I'm the "new kid on the block" so to speak, and was wondering if anyone would know where I might get timing advance and dwell specs for 2 mercruiser 888's I have. I've recently rebuilt both engines and gimbals and installed rebuilt outdrives. Both are ford 302's, 1973 and 1975 model years. The local marina is unable to help as they are understandably swamped with repairs at present, and the Clymer book I have doesn't list this information. I set points at.017 initially and 10 degrees advance and they start and run fine above 1200 rpm but refuse to idle no matter what I do to the carbs or advance. The '75 with the rochester 2 bbl is touchier on this than the '73 with a holley. So here's hoping someone can point me in the right direction and thanks in advance. (no pun intended!) pete
With these older engines, I would suggest you call Mercruiser's Stillwater, OK plant direct. Have your engine serial numbers handy...they'll need them.
Secondly...get yourself a Seloc Manual in place of the Clymer...Clymer's aren't as detailed. Or, better yet, when you're talking with Merc...see if they still have service manuals for the triple 8's.(Manual#1 90-68648 1963-1973 Engines & Drives - All,Manual#2 90-71707 1974-1977 Engines & Drives - All)
Mercruiser:(405) 377-1200
Thanks mike, will do, and the part numbers are appreciated. pete
