MILKY OIL
well... that's short !
Raw or fresh water cooled ? salt or fresh water ? how old are the manifolds and risers? any signs of overheating before that happened ?
PS: turn off all caps when posting.
fresh water, new to me
boat has only been out a few times
every thing looked good except oil pressure was low when docked last temp went to 200+ at ilde so throttled up and it cooled down but i think the water pump has a loud tap or clunk only realy heard at start up
first thing is to drain the oil/water mix, change the oil filter and pull the plugs to see if you any cyl. have water in them. If so, that could indicate which manifold has a leak. you'll need to pull the manifold and risers, that could reveal the source of the leak. have a mechanic inspect and test the risers and manfold, if they're old, rusty, etc.. they're due. in salt water, 5 years is the average lifespan... in fresh they will last longer obvioyusly.
then, you need to "rinse" the engine with fresh oil. Refill the cranckcase, leaves the plugs off and crank a few times, letting the starter cool off in between. the goal is to circulate oil around to remove water. do this twice, the first time you can use diesel instead of oil as it's lighter and will rinse the engine better, although with fresh water you dont' have to worry about salt deposits.
well, then you know the source but you shoudl still get the manifold and risers checked since their age is unknown.
if you intend on saving the engine, you still need to flush the milk out and curculating some oil in there....
