mobile hotspot
That might be worth a try. Actually the only reason I need a "hotspot" is to run my printer, but it does just as well with a cable. So it's not really a priority, and neither are movies. So for the time being I'm not going to worry about it. When the prices come down for hotspots and unlimited plans, I'll look into it again.
getaway
Check your usage again.
While broadband may show zero, connect/hotspot will show actual usage.
ronbo
How do they know packet sniffing and MAC addresses of every device attached. It isn't that hard and I just read an industry article AT&T has already started sending out notices to people that are tethering and not on a tethering plan. I prefer to be honest I pay for data and a modem usage which is exatly how I am using my various modems. Many people want to complain about coverage and speed issues yet everyone thinks there is no cost to the carriers from theft of service or improper use under the terms of service. Check your contract and the Terms of Service if you are within the rules your fine if not and you think you have a sneaky way around it like cloning MAC addresses, computer sharing programs or devices or aliasing them you might find yourself capped or blacklisted. I remember the guys that used to sell Direct TV receivers that were cloned or open sourced cable modems some ended up with heavy fines other's went to jail.
^ If you are referring to my post about not paying extra yet, let me clarify that everything is on the up and up. Verizon has not implemented the extra charge yet. I specifically asked them if mobile hotspot was allowed on my current plan and they said yes. I'm assuming they are going to assess the extra charge at some point in the future.
I am not pointing out anyone just saying there are changes and you can really thank NetFlix for starting this. The pipeline is being choked by IPTV and huge file sharing backbone providers like Level 3 are complaining. The cellular industry is changing and Verizon announced last week that they will have 108 cities with LTE on-line by year end. I'm going to use which ever modem works best on my boat for where I am at. 700MHz LTE goes alot further (better propagation) than 2.7GHz WiMAX on Sprint/ClearWires so called 4G network. Another industry paper was just released the last couple of days where 1000 concurrent data tests were done with VZW 4G LTE vs. Sprint/ClearWire's 4G WiMAX and there wasn't a single test where the VZW LTE didn't totally blow away ClearWire.
This was a comprehensive test of the NYC area comparing the 2 networks.
I have a 3G MiFi hotspot and just ordered a VZW Samsung 4G LTE Mobile Hotspot upgrade I expect to get this week. the 3G unit has worked great but maxed out at about 3-4MB down- I'm hopping the 4G is much faster.
i used a 3G wifi hotspot while in the UK last week and hooked up at 6Mb down & 3Mb up- much better than ours
Consider yourself lucky Andy typical 3G EVDO speeds from NJ to Washington DC are less than 1.2mbps DL and .800mbps UL on EVDO RevAe on VZW. I find the best speeds are early morning as in pre-dawn and very late at night.
I have run several speed tests using spreedtest.net.
With 3G signal, best download was 3Mb, most of the time more like 1.5Mb
With the 4G signal, consistently at 10 to 11 Mb. I believe the upload speeds are wrong as someone else pointed out as the upload shows twice as fast as download.
Of course, now I just ran the test twice with 4G signal, and only got 1Mb down. Now I'm beginning to wonder about the app.
The Max speeds I’ve reached were indeed early AM (5AM+-) at LGA waiting for the DC shuttle, which i do often.
But I often get 2Mb+ at home on long island.
Sadly, those speed won't last too long once all the rest of us get 4G phone (I'm waiting on the Bionic).
Here's some detail about the SpeedTest.Net app and the incorrect upload speeds:
http://www.droidforums.net/forum/htc-thunderbolt/133631-thunderbolts-speed-tests-arent-accurate.html
If you're using the Speedtest app by Ookla to test your Thunderbolt's speed, you should be aware that the app is incorrectly reporting crazy upload speeds. Engadget contacted Ookla and here's the quote:
[Update: We've been told by Ookla that the Thunderbolt's massive send buffer is responsible for the erroneously high uplink speeds -- they've got a fix in the works and it'll be available as an update to the Speedtest.net app soon.]
Perhaps try using http://www.speakeasy.net/speedtest when tethered? I'd offer to let you use my FTP server to really test it, but those darn 4G speeds are faster than my business-class connection to my server!
...... but those darn 4G speeds are faster than my business-class connection to my server!
Kurt
Who is your ISP? for Biz-class thats seems very slow
Its Verizon 4G
I changed the server in speedtest.net (its an option in settings) Went back up to 11Mb.
Not sure why it is server dependent
Your one of the lucky one's getakey because you have 4G in your area. We should have it in our cruising area in the next year. I will get to use the 4G LTE service later this week when I will be in the Philadelphia area. I sure wish we had it at the Jersey shore Atlantic City area now.
Has anyone looked at Virgin Mobile? Unlimited text and data for $25 / month,with 300 minutes, after buying a phone for $129. What's nice is that since it's pay as you go, you can turn it on for the season, off when you haul out. Two caveats -- you need to download a hack to make it a hotspot (no biggie, and it works well) and the speed is only 3G, running on the T-Mobile network.
Went to the boat today. Worked well. Able to connect direct to TV. Browsed a few Internet TV shows and watched some movie trailers. Had other work to do, so did not have enough time to watch a movie.
Very happy with the performance. Only one problem: could not connect with the custom password I assigned, but could connect with the default pw. Will trouble shoot that next time.
Logged on Verizon to check my data usage after testing hotspot on the boat.
Same as before: There is usage under "Domestic Data", but zero data under "Mobile Broadband"
I think they cannot measure the hotspot activity yet, so that's why they have not implemented the additional charge on my plan.
getaway
getakey
I had the same discrepancy.
Instead of tapping Usage Details for your hotspot usage, tap the
(+) on Connect/Hotspot. In my case it was 1.17 GB of 2 GB.
I know it's right as I recently got a 50% alert of usage.
ronbo
where is the (+) on Connect/Hotspot?
Do you have a Thunderbolt?
This is what I have found in the Android forums regarding the Thunderbolt:
Mobile Hotspot will be included through May 15 for no additional charge. After May 15, customers may choose to activate Mobile Hotspot for $20 for 2 GB of data per month. Customers can track their data usage by downloading the My Verizon app available in Android Market or by logging on to their My Verizon accounts online at www.verizonwireless.com/myverizon.
I was joking. We use Comcast Business. I think it's about 20Mpbs down and and 5Mpbs up. Not bad for $105/month w/ 5 static IPs.
Getakey, I am right in front of you on the G dock and use a Sprint 4G hotspot. I can't get a good 4G signal on the boat, even on the flybridge. I get a great 4G signal in the office though. I end up just using 3G on the boat which kind of sucks. Sprint also has a 5GB data limit on the 3G network. Data is unlimited on the 4G network. I get similar speeds with a good 4G signal on the Sprint network.
