Money saving boating tips
Originally posted by RadioguyJ
Some people I know shut down an engine when boating through a no wake zone to save fuel.
You have got to be sh!tting me!!!
I'm very lucky. We boat on Biscayne Bay. Most of the time we motor less that an hour to our favorate spots and anchor out. we turn up the radio, fire up the BBQ and have a great time. doesn't really cost much fuel at all.
Originally posted by SLW
Buy Smirnoff Vodka in the largest bottles you can find. Refill your Grey Goose bottle with Smirnoff and serve it to your guests who believe they can tell the difference after mixing it with redbull, tonic, juice, etc. (they can't) When serving martinis to discriminating drinkers, you might have to pull out the good stuff, but otherwise Smirnoff goes down smoothly and if you party/entertain like we do, you'll save enough cash to buy a tank of fuel.
Oh brother, you must be joking.
How to save money on a boat...buy a canoe.
Mike - I idled on one engine just last week. Several times, while waiting for freighters to exit locks, we had wait for extended periods of time. I need to maintain some sort of control, but it doesn't make a lot of sense to run 2 big blocks for half an hour when they're not needed.
That makes sense. What I responded to was what Jason said...since I know the no-wakes in these rivers and there is no need to cut power. If I was waiting somewhere...I'd shut down as well.
Originally posted by pdecat
To seal the ends of cut lines: Tape the line tightly with 1” tape then cut the line in the middle of the tape using a sharp blade leaving ½” tape ring on each cut end. Dip the cut ends into plastic pipe glue and let dry. You can use that liquid whipping stuff from the boat store if you want to spend more but the pipe stuff works well for me and I always recognize which lines are mine because of the blue ends.
Do you mean PVC pipe cement or something else? Something you can pick up at Home Depot or the like?
Mike, yeah, I'd be nervous about running on one wheel if there was excessive current and/or limit room to maneuver, but without those restrictions, it's a decent way to save fuel and hours.
Walshie, nope - not joking at all. I'm not sure what stood out to you: that I refill bottles or that it saves a lot of money, but I can assure you, both are true! On a big wkd, we might pour over a gallon of vodka. If you slice the cost of that by a third, it adds up pretty quick!
Weld her to the dock and just sit on her and drink. Or, take the boat out then come back and sit on her and drink. Don't forget to cut her loose so she can drive you home though!!!
I'm with Jeff. Stay at the dock and PARTYYYYYYYY!!!!!!!
running on one engine ins't going to save you much. at idle, waiting for a bridge or lock you're barely sipping fuel and when running at slow speed it takes the same amount of power to propel the boat, you're just saving on the extra friction in the engine and tranny. if you do, make sure your tranny (inboard) can handle freewheeling.
I learn more about boats and their systems from BoaterEd so I'm not having unneeded repairs. When I do need repairs, I buy my parts from BoatFix.com. Save a lot of money there! I don't cut back on my boating to save fuel though.
Sometimes I convert my credit card bonus points into gas cards.........
Pascal: There are so many variables it is difficult to be accurate but I seem to get 2npg at about 8.5 knts and near three at 7.5 on one engine. The problem is that I didnt go far enough on the test run to really be sure, only 150 mi or so. :)
I use washing machine hose for chafe gear on my home dock lines. It is cheap enough that you can use long pieces to fill the entire pole loop so there is no chance of it slipping as with off the shelf chafe gear.
Marry a boat mechanic.
I know most of them come in male formats, so for you guys, you will have to go for the domestic partner relationship providing it's legal in your state.
I am REALLY thinking about it.
Bruce... to compare apples to apples, you'd have to compare at the same speed... you cna be sure that on two engines, you're burning less at 7.5 than 8.5 kts. the question is how much less ?
bottom line is power needed. i would be willing to be you are chasing nickel...not dollars trying to run on one engine...
do my own maintence serves two purposes...saves money and teaches me more about my boat.
also instead of running out to our favorite sandbar on saturday, coming home then running out on sunday again..i just spend the night, a new anchor and a ton of chain were paid for in a mere month.
Sometimes it's the simple things that can be done to save money. When I go for a cruise I take the time to properly trim the vessel using the trim tabs (can be done with I/O also). The amount of gas saved is really significant. On my vessel I can gain about 1-1.5 knots by trim alone. At cruising speed of 17 knots, that's a gain of almost 9%.
