Mooring whips
OldMariner32
It will be a while before we install a boat lift at the lake. I was wondering what the pros and cons of mooring whips were. I never saw these at the lake where I grew up, but they look like an interesting idea. What are your thoughts?
They were installed in Reef Point Marina in Racine, WI in 1988. If memory serves there were over 100 of them. It wasn't five years before they were all gone. I think they were more trouble than they were worth. I think the lines and poles were in the way when docking. They might serve on your single dock.
Would I be better off just to put a couple of cleats on the dock and hang a couple of fenders over the edge of the dock? I can only tie the boat from one side.
I have never seen them in action but the concept is sound. They are ridiculously expensive for what you get.
Is the lake tidal? What is the bottom? Sand? Rock? Mud? I may have some alternative and cheaper ideas that are a compilation of stuff I have seen and done over time.
No, there are no tides. It is a man-made freshwater lake. We are at the creek end and there is a spillway at the opposite end. The water level only fluctuates in droughts when it drops a bit below the top of the spillway.
When I say that the bottom is sand it is misleading. The sand is so packed it is nearly as hard as a rock.
Here in Florida, I have had whips for the last 25 years. Most house docks have them here and they work great. Only troubles I had is
1. I snapped one leaving the dock in a hurry forgetting I was connected,
2. Once they were stolen when I left them on the condo slip and wasn't there for months.
I would not be without them in Florida, however I was fine without them on the St. Lawrence.
One further bit of info. Our dock is on the edge of the no wake zone by the boat ramp, so when people start out we get the worst of the wakes.
I have them for my bowrider, they work great. If you have a low profile ski boat like your avatar shows they won't get in the way. You need to get everything adjusted correctly - the angle and the length of the lines.
Also, consider your dock structure. You would be attaching a small bracket held by three lag screws into it, and a fair amount of force converges on that point. You can't just attach it into a thin deck plank, or the plank, whip and everything will just pop off right when you need it most. You might need to buy longer heavier grade fasteners than what they come with so you can get down into something solid and anchor it well.
i use them as well as fenders. on my canal i get surges from boat wakes. the whips hold the boat off the pilings 99.9% of the time, when it does hit the piling the fenders are there to take the lumps. before i put the whips on, the fenders would actually wear at the wax and gel coat. not really any downside to having them as long as you remember to untie them before you leave.......lol.
I've used them for years. The ones I currently have for my 36' are rated at 20,000 lbs. each. The cost was not bad, I bought them directly from the manuafcurer and picked them up at the factory in Ormaond Beach, FL. Moring Products have a website and if I remeber correctly I think I paid about $400. which was cjheaper than WM and other retialers and a much better product (Rocker arms) and mine included all of the options, cleats, lines, etc. Would never be without in the future. Have worked well in several storms here in Florida.
One other comment I might make is, I find it handy to leave my dock lines threaded through the eyes in the lines hanging from the whips when I go out. When I come back, all my lines are hanging in the air, 3-5 feet away from the dock. Very easy to grab them from there and pop them on the cleat. This really helps my daughter out when she takes the boat, since she is not 100% comfortable with docking as yet.
Ron,
What brand are you using?
There isn't much explanation in the catalog. Do the whips attach to my cleats or to the lifting eyes?
If I understand it right, I can somehow reel the boat in closer to the dock for boarding?
I use Monarch Mooring Whips with the adjustable base. Have used them for years without a problem and they keep the boat away from our bulkhead which has approx. a 3 foot tide difference.
Ron, that's a great idea to use the dock lines through the eye. Have to check mine as I'm not sure they'd be long enough to go through but it's worth a shot.
Honestly mine are so old (20 yrs maybe, got them used from a friend for a good price, $0) that any label is long gone. Mine are the simple ones that do not have the "release" feature. I just pull in on a line and get on the boat, then take the stern whip line off the cleat so anyone else can board easily. I guess the ones that release could be made to pull away with more force, which you would seem to want to do with those wakes you have.
I don't have any lifting eyes, so I put them on the same cleats I tie up the boat with. That makes for a different angle on the bow and stern whips, since the bow cleat is in the center and the stern cleat is inboard, but that's just a quick adjustment.
I don't think there is any right or wrong in terms of what you attach them to. The whole point is they flex, so they don't put tremendous loads on your cleat like a dock line could when it jerks.
I called Monarch and they quoted me over $300 not including shipping. Dockmate and Dock Edge both have whips for my size boat that only cost $180. I don't want to pay more and get the same thing, but I don't want to throw my money away on trash either.
It is interesting that no one said they were junk and switched from whips to something else.
I sure appreciate all the feedback. BoaterEd is definitely the place to get your questions answered.
(By the way, Flatsflyer, you aren't the same John Coffey that was in the 313th MI Bn of the 82nd back in the early 80's are you?)
,ooring whips are great, when i lived on Winni in Nh at the time there werent many lifts at all but everyone had whips
2 chain link fence poles about "X" feet long. "X" = average water depth + how high you want them out of the water * 2. 2 garden hoses. 2 jet sprayers for the hoses (the driveway cleaning kind. Some plastic cable ties. 2 eye bolts w/ pulleys attached and the nuts and washers necessary to attach them to the posts.
Attach the jet sprayers to the garden hoses. Cable tie the the hoses to the fence posts. Attach the garden hose to a water source. Outboard of the boat, sink each the pole to the desired depth via water pressure. Yes ladies and gentlemen, this really does work. Drill holes for the screw eyes and attach them to the poles.
Two options here. one is to run a line through the pully with a weight on the far end and attach the other end to a boat cleat. The other is to use a snubber or the like to the pulley and cleat to keep tension drawing the boat away from the dock. Maybe $50 total. When you rebuild the current dock into the uber dock, you can get whips.
My 2 cents.
We have them mounted on the swim platform of our Skipperliner. We use them to tow ski boats. We have Monarch brand.
