Originally posted by Sandy
Are you sure you have SR controls and not the Twin S (with ID plate on top)as on my '88 Phoenix? I don't think the SR's have any friction control std or optional, not sure. The Twin S does have an optional Throttle Friction Control , Telelflex marine # 306997 :
http://www.teleflexmarine.com/cgi-bin/library.cgi?site=enginecontrols&type=us&library=1017
Also,the handle bottom screw on the "S" series is supposed to be a friction brake control.
http://www.downloadingfiles.co.uk/teleflexfiles/library/instructionmanuals/055000-049 Rev1.pdf . I don't think it does much on mine.
Two other ways of reducing chance of creep I'm aware of, which are NOT highly recommended, are (1) to either create add'l bends on the cable or reduce the radius of an existing bend (min. bend radius for std teleflex cables, Red Jacket & RJ Supreme I believe is 8", for Xtreme cables it's 4"), ...or (2)apply a home-made "cable brake". The brake someone put on my boat long ago is a strip of SS maybe 1 1/2-2" (?)long x ~1/2" wide with 2 90* bends in it so it forms a "U" with center span longest. A hole is drilled thru the center of one of the end spans, and the hole tapped to accept a hex head machine screw screwed in from the inside of the "U". The brake "U" is slipped over any accessible part of the cable jacket and an open end wrench used to back off the screw so the head squeezes against the cable and deforms it slightly. If not used very judiciously, either of those methods can create permanant binding , but have been known to work OK if done carefully.
Edit: It sounds like Captddis has a much more elegant solution that I wasn't aware of, having been "advised" long ago the SR weren't friction adjustable. Good work.
