Most compact "real" dinghy?
mchad
I need a compact, roll up dinghy that rolls to the smallest size. I want a real ding, not a cheap blow-up toy, with a capacity of at least 600lbs, and about 8' length. I currently have an old Merc 260, which has slatted floors, but a tube transom, with a "clip on" motor mount. The mount becomes pretty unstable when under power (using the recommended 4hp) so I want a hard transom on the new one. I like the idea of HP inflatable floors, but am not sure of their longevity or stability. Price is of obfious concern as well...
Any suggestions?
I had some thoughts on the subject, but not much help at all.
My first inflatable had Floors n' Transom. Bad! Not real bad, livable but bad.
2nd did too. Cheap stuff that required lot's of patching.
Those were short, and the older thinner fabrics.
Finally I put out the bucks and got a 13' Metzler. Hypalon and 100 Dinear cloth. I think it was rated at 1200 Lbs, and a 10 Hp motor.
With just me and some stuff it would go 6 Mph with the 6 Hp Johnson.
It had an inflatable floor. Cleats and D-Rings on re-inforced patches everywhere and a Safety rope spliced into the sides.
A replaceable middle Wooden middle seat which would lash onto the sides somewhere allowing the boat to be used as a big water bed for camping or for lots of bulky cargo. I slept in it several times. I'd pull a 'wallmart' blue tarp up over me as a tent to keep the Dew off my sleeping bag.
With the middle seat in, it was a great rowing skiff.
I could stand up in it easily. I did a lot of fly fishing in the lakes and in Salt Water in that boat.
The Transome was inflatable with a wooden and stainless area moulded in for the outboard. It had one design flaw back there. I used a 6 Hp Johnson (usually) and when it was loaded (two guys, the camp and wepeons and most of a Moose) that transome area would dig in, and shower the operator pretty good if you gave it full throttle.
It also had a 'tie-down' area for a Battery that was re-inforced and I used an 18LB thrust Montgomery wards Electric trolling motor on the lakes that wouldn't allow Gas motors. I had to row back lots of times.
You mentioned a 'roll-up'!
That Metzler came in a bag. The Oars were in the bag too.
The whole package was 89 Lbs. Unweildy but managable by one guy.
The Bag was about the same size as a very large Lawn trash bag.
It had handles and Back-pack straps.
It was a very heavy un-wieldy package when fully restored into that bag.
There was no place in the bag for a Patch kit. That had to be extra.
Getting that thing back into that bag required lots of room. My front lawn eg:
But the thing you really needed was a Vacuam cleaner. Those Inflatable pumps that can be reversed just dont do the trick.
Even with a Vacuam cleaner you needed two guys. One to ensure the Vacuam was applied at the right time, and the other guy to be folding and rolling as the opportunity would arise.
It was not something easily done in the crowed end of a Cruiser.
All the Valves were safety valves. It was a really safe and very good inflatable. I had it for Seven or Eight years.
One more thing about RIB's. If you live in a cold climate (I was in Alaska) the Bag and boat will freeze in the winter.
You cannot monkey around with it when its frozen or you'll have weak areas that look like creases and eventually they will begin to stetch and more than likely will need a patch.
A Novarania and an AVON had those experiences.
The Good ones, are surprisingly easy to Patch. Re-inforcing an area for a Sun-deck or some special purpose is easy too.
The Patching comes in all the popular colors.
storing them out in the sun will cause the Hypalon to sepearte from the Fabric. Then you have a mess!
I probably had more to say...but your 'roll-up' caught my eye and I almost laughed out loud when my Son and I learned the awful truth about "....and this one roll's up and stores completly in this handy storage bag...!.
I bought a Titan 7'6'' with aluminum slate floors. It has a capacity of 660 lb and I think it will take up to a 4 hp . I use an electric Minn Kota motor on mine. I bought it In Canada and paid $700 cdn at a boat show . I am into the 4th season with it and all seems good so far . It is the type that has a hard transom with the tubes extending about 14" past it. Hope this helps
I did see a vendor selling a new-in-box Mercury 2005 Quicksiver 240 RU (Roll Up) It has the capacity I need, uses the built in "slatted" floor, and seems to go down to a small and light weight package for stowing. Best of all it is $780 delivered. My only hesitation is that I have heard of quality issues with Quicksilver dinks, so I am wondering if anyone has experience with any of the more contemporary models..
