Moving under power! Finally...
Moderator
Almost a year after launch, I fianlly installed the inboard electric motor on Sabrosura... It's supposed to be th equivalent of a 10hp motor, powered by a 48v bank ( 8 golf cart batteries) and run by a sevcon controller.
So far so good. It's pushing th boat nicely at very low power setting. Haven't run any test yet to see top speed and range as we re really jsut going to use it when th wind dies down coming back and to assist for occasional docking. We still intend to do most maneuvers including picking up or dropping th mooring, the old fashion way, under sail!
The motor is connected to the shaft via a 2:1 belt driven reduction and turns a 10" 3 blade prop.
For n ow the batteries are going to be charged by a pro mariner charger when tied up to the club dock or to my boat. The bank is used only for propulsion, we have a 12v g31 house battery with a solar panel.
I may add solar panels for the new bank, although storage is an issue so not sure about it yet,
Here is a short clip of the first trial run.
http://instagram.com/p/wxZyjIscLm/
Wasn't stagesd... I finished connecting everything while Naomi was rowing in the club mooring field so I dropped the lines and went to surprise her... Just happened to be a nice sunset!
How has the boat performance changed with the added weight?
For shame! No running lights? ;)
But seriously I think you need them now.
I Ve had running lights since the day we launched, we spend a lot of time sailing at night! It was still pretty bright and the sun has set less than 15' before :)
No change in weight really, I had the same number of batteries since we launch, it was some old go,f cart batteries from an old inverter bank I no longer use
Nicely. Does it need to be registered now?
It is...in Florida anything over a certain length Needs to be registered whether or not it has a motor, I thnk it s 18' .
