- Jul 27, 2001
- 5508
- 1,255
On my boat when the lanyard is pulled or even loose I get no power to crank, nothing on the dash volt meter, and nothing at the coil to deliver a spark. I am getting plenty of crank, 12.5+ on the volt meter, and spark for 1-2 complete engine revolutions. Then something tells the ignition relay to trip, and no more spark.
Two deliveries are on their way to my house - a replacement ignition module - which is somewhat of a hail mary, but at 80 bucks figured it was worth a try. And a merc ten point plug so I can power the starter and ignition without depending on boat wiring and ignition switch. Actually I could jam a wire into the boat end of the 10 point plug to accomplish the same, but figured it would be cleaner- could even go boating if it comes down to it- with the homemade harness. If neither of these get it done, I'll need someone with actual skill and experience to fix it. So will have to decide if I want to put the 350 back in for June boating, or just trailer it somewhere and wait until they can fix it.
Man, those ECM's are pricey. I wish I would have kept mine when the original 454 bit it 12 years ago. I sold it on ebay, don't think I got more then 200 for it. These days they run at least 600, as much as 1,500. It's a delco part, would think an auto one would work, but I guess not?
