Mr Coffee Repair
I finally learned how to make decent coffee in my Mr Coffee that came with the boat and during my vacation this week it died:( I can't find any new ones the are the same size to fill the space.
Does anyone know if these units can be repaired? It powers up the clock works but if you try to brew it doesn't work and auto start just turns off when it goes to activate.
I like the way the unit fits the cabinet I would rather pay more to fix it then to buy a new unit that will look funny in it's spot.
Toss it and buy a keurig. Unless you drink a lot of coffee. Tnere is a lot of storage behind it. Over winter I am going to get a doormade to match the oother side too.
Call Joe DiMaggio
LOL
If I thought a second door would match I would do the same! I have notice the storage but the coffee maker comes off so easily I could store stuff I only need occasionally without it being a problem. Audrey never liked coffee and suddenly she discovered she likes iced coffee so we make a pot and whatever I don't drink she throws over ice works for me! I have a keurig I like, I would love it if they made one that fit the space perfectly! I like things to look finished and original if possible.
Thanks for the links unfortunately it seems parts are discontinued and no longer available the closest repair location would cost me more in gas and tolls the a new top of the line unit and even they can't get the parts.
I guess I will open it up and see if there is something easy to fix with parts from Rat Shack. I suspect it's just an inline fuse to the heater element or something simple like this. I guess worst case I have John make two doors:)
I think the door will match if I can find some one to make it. I have the small kuerig unit. KT just sits on the counter.
I have a customer in the custom furniture and cabinet business, I had them remake my entire cabinets and table on my last boat it looked great but I had them all done so everything matched. If I had to pay for that job I can't imagine what it would have cost! I sure I could have them make a door but I'm sure I would have to pay this time being they are under new ownership it may be worth it. Let me know how you make out and I'll go from there. If I decide to have it made I look into having two done I'm sure they are exactly the same.
BTW did you notice even the hardware says Trojan what where they thinking?
I might need to get the name of your furniture guy as I have not had much luck finding anyone yet.
Yeah those plastic caps pop off pretty easy. I used to know a place that would make those custom. I am missing a few and have moved them around from areas less likely to be seen.
I'm not sure if www.abtecparts.com can help with parts. They had a heating element for my coffee maker. I had the same problem where my coffee maker is no longer made and it fit the space perfectly.
My customer really doesn't do small jobs like this the last time was a huge favor I would feel funny asking again but I might have to. If I go this route I will let you know it would not be a big deal to make two at the same time. I might try to remove the existing door flip it over and see how well it fits. If it is perfect then it should be easy to bring it to them to duplicate. My wife is OK with a small removable shelve and storing the toaster on top. The toaster fits well but is a little short the shelve would give me a little storage and make it look like it belongs. Then I could get a Kuerig and be happy.
We currently have a small toaster over in the space between the cupboards. I have noticed though that tuned microwave seems to take a long time to get things cooked so I plan to replace it with a combo unit.
Jim you will find with a little bit of AC load management on the Microwave side they cook alot faster. If I am running the front AC unit, one of my 40 amp chargers other small stuff on the port side AC outlets and the Microwave it takes almost twice as long to cook food in the Microwave. If I turn off the stateroom AC unit the Microwave cooks almost twice as fast. Each device is directly feed to one of my 30 amp split AC panel's legs. I ended up measuring the voltage at the Microwave and it was at about 100 VAC when cooking and the front stateroom 16,000 BTU AC unit was cranking full output. If I run my 7.3Kw genset I don't have the problem with AC voltage sag anywhere especially at the Microwave. I replaced the original Microwave last year. The problem is not the boat but where I dock in relation to the transformer that feeds my side of the marina. I am almost the furthest boat on the dock from the feed for my dock.
John as well as my boat have a 250 50 amp feed to the boat that is split at the main panel into two 125 volt 50 amp input one of the feeds is used for the two ac units the other is used to power everything else. I would be surprised if he has a power problem do to load in the boat but you might be right that the power coming into the boat may be low. I know that the boat at the end on my dock was having a problem due to being the end of the line in the run there was a voltage drop.
My microwave works great however the display is hard to read I may pick up a new one as well at some point. I think it may be hard to find one that big it's huge. It is the biggest microwave I have ever seen (I'm referring to the inside cooking space).
My original Microwave a Panasonic still worked Dave, but like your unit it had seen better days. It was almost impossible to read the old LCD display, the backlighting stopped working and it was starting to rust near the door's seal (not good or safe). I replaced it with with a new Dometic low power microwave 850 watts. I knew the unit wouldn't work any better with the dock's power issues but it's really clean compared to the 18 plus year old unit I removed.
I only have dual 30 amp service available in the boat and at the marina. It's actually enough with some basic AC load management.
The power on our docks is the limiting factor.
Originally posted by rgy
look on ebay for the same model
I have looked but being my boat is a 96 I think the unit is long gone.
Thudpucker strikes me as someone who could make an outboard motor out of an old toaster oven. Send him your coffemaker; if it's not repairable, maybe he can convert it into a FLIR system.
