Muskrat Protection
Scugogbob
Does anyone know of a guard or something that can be installed to protect the bellows against these critters.I have a 1900 2007 with a 4.3 gxi
Last year a boat was sunk on our beach. My mechanic tells me I may have the same problem soon as there is evidence of nibblings (is that a word). I am looking at a boat lift which will solve the problem but a guard would be a lot cheaper. Any advice would be appreciated as I am a novice stern drive owner.
2007 Regal 1900 4.3 GXI
Are you leaving the outdrive in the up or trailer position when away from the boat? I'm trying to figure out how a muskrat would get to my bellows when the drive is in the down position. Am I missing something?
ITK's got it. I my outdrive down and on a lift and have never had a problem...with the boat...they are constantly burrowing in behind my seawall and boardwalk. This spring I was trimming monkey grass around the dock and found a cavern about 4'x4' they had burrowed behind the seawall. People who don't know think they are cute, I hate them. Regarding the outdrive, if you keep it down I don't see how they can get to the bellows, they will however chew up other rubber things like speedometer tubes etc.
It takes about 1800 Muskrats to make a fur coat.
What about something really exotic like an 'electric chair'?
Use a Fence Charger on a Chicken wire mesh.
If you really wanted some action, get a home-made device out of an automobile coil.
Use the grid of Chicken wire and a Capacitive switch. When the Seagull or Muskrat steps on the Chicken wire he gets 10,000 volts. I'll bet he'd jump a good five feet in the air.
You'd have to put a 'man-readable' sign up to warn folks though.
If the boat is in the water how do you keep the charged device (chicken wire, single strand, etc.) from at some point touching the water?
G
Oh! oh! There goes thud trying to electrocute something again. Kinda like he's going thru an extended second childhood.[:O][:P];)
My boat is on the Trent- Severn system , water height controlled by locks etc. Last year a lockmaster left the logs out and we lost a foot to 2 feet of depth,therefore my drive was up or on bottom. I am thinking that is when they got me. Thank you for your responses. I see a lift in my future.
G
Wellll... a Magical thing happens in the middle of my Equasion.
I dunnoo, I guess if I was somewhat younger, more energetic etc, and had a few Cats to use as experimental subjects, I could come up with an answer for that one.
An Idea for starters would be a scan that's a combination of Ultra-sonic, and Infra-red.
Sorta like the Intruder scan that turns on the yard light.
Set a relay for 5msec to gate the Car Coil.
After 15 seconds or so, if the intruder is still there, and still 'warm' hit im' again, and keep that up till one term or the other is no longer true!
Charlie I'm not completly guilty of that Idea. I knew a guy in High School that wired a coil to a push button so he could Zap the guys who always seemed to want to lean on his car.
I never saw it happen, but its still in my mind after all these years. Still waiting for an opportunity.
Thus, the old Ford Spark Coil trick has been around a long time. In college a friend wired one to his room door know with a mercury switch. The switch was rigged so that if you turned the knob the normal way you would get zapped. Those in the know turned the know opposite and did not get zapped.
When I was in the feed store business I sold the "store boughten" ones for many different purposes. One different purpose was to a fox hunting club. (Actually this was rather common in this area.) They had a one mile square hunting area that was fenced with chain link fence. Even though it was fenced the little bushy tailed devils could still dig out. The hunters ran a hot wire all the way around the inside abour 18" from the fence and 6 inches off the ground.
I have used one to keep my dog from jumping on the kitchen glass door. I fastened a strip of metal tape about 40" from the ground and ran the hot wire from the fence charger to that tape. After my then German Shepard hit that a couple of times he quit jumping. I still have that one around here somewhere.
G
I wonder if you could hook up one of those piezo(sp) switches. Like the kind in disposal lighters. No need for betteries or power. I zapped myself a long time ago.
Bubble Gum. Place the gum in a place thats easily accessable for the muskrat. They love gum, but can not digest it. It blocks their digestive systems and they die.
It sounds strange, but we tried it. The muskrates either moved out or they died. Either way, it worked out for me.
Cool Wishoot, I didnt think there was anything in this world a Rodent couldnt eat.
I used to catch them in my Chicken feed (Alaska) and sometimes they'd be so chilled I could easily club them.
The Taxidermists want all those buggers. Bring em' in whole though!
