My New Theory
Doc
My new theory about rusting one pound propane bbq bottles follows after some review:
The review: In a recent post I complained about the Wal-Mart propane bottles that were dripping rust on my boat because they had a metal bottom with holes exposed instead of a plastic boot on the bottom. Being frugal I didn't want to throw anything away so just now have I used up my Wal-Mart bottles. So, I bought two new ones from K-Mart for a little more money (with plastic boots).
I had a little gas left in my Wal-Mart bottle but took it off and put on a K-Mart bottle (with boot) and fired up the Magma Monterrey. After it warmed up I noticed that the bottle was frozen over and the flame was not very high. Hum...so I put the old bottle back on (no boot) and....no ice and a much hotter flame.
My new theory is that the boot interfers with the shedding of cold and shuts down the flame. The manual mentions this. So what do you think?
I don't know how something freezes in Ft. Myers, FL. Am I missing something?
Don, been using bottles with plastic bottoms and never experienced freezing up...
Doesn't it have something to do with a liquid changing into a gas ?
I noticed that problem on my home gas grill after putting on a refilled tank. Couldn't figure it out because it didn't do it before. Same symptoms, ok for awhile, then the regulator iced up and it would barely hold the flame. Tried wrapping rages around the regulator but it didn't help much. Then one day it just stopped icing up and the flame was fine. My uneducated guess was that it was overfilled and this was somehow causing the problem.
Propane/butane is a liquid that flashes off to a gas. When the gas on top of the liquid is taken off too fast, the liquid will get cold when the pressure drops in the canister. You can dip the canister in warm water and more gas will flash off inside the canister and give you more pressure and flame. Or wrap a warm rag around it for a minute or so. If you are using a tank like on a home bbq pit, you can hit it with a water hose and do the same. The propane tanks on my fryer and boiler does it all the time because I am using gas at a high rate.
Doc, yes. Higher pressure going to low pressure causes a loss of temp. I've always noticed they tend to ice up just before going empty. The faster you use the gas, the higher the chance of freezing the regulator.
OK, great feed back. Now, my theory is that the non booted canister with small holes drilled in the bottom stays warmer than the one with the boot because the cold can disapate more quickly around the holes.
