1989 Silverton 40X with 502's
Both engines run right at 140 degrees....consistently. I had to change the fuel pimp on the Starboard Engine about a month ago and as long as I was down there I gave everything a thorough looking at....(hose clamps....check EVERYTHING for leaks.....corroded wires etc.) and noticed that the Port side coolant reservoir was bone dry. It was also dry when I splashed for the season about a month and a half ago and I topped it off of course. Since then I've put about 80 miles on it (hour meter is disconnected for some reason which I'll take care of next week) and now it's dry again. I pulled the engine cover completely off so I could get at EVERYTHING and don't see any visible leaks. I know you're not supposed to mix different types of Coolant but I bought a gallon of RED Coolant and topped the tank off.....ran it for about 30 miles.....Bone dry again.....Checked EVERYWHERE for leaks and no sign of anything red anywhere.....topped it off again with the red....ran it about 20 miles.....bone dry again. This is a closed system and the engine never gets over 140 degrees .....I DIDN't top it off this time but instead took it on about a 20 mile run yesterday......temperature ran right at 140....
This engine doesn't do anything strange such as a misfire or blow any smoke gray or blue.....idles perfectly...starts right up with no problem and has all the power it ever had since I've owned it. (about 5 years now)
Sooooooo......Where's the Coolant going?.....????????????????
