Name This Boat???
gcolton
Well-known member
Do you recognize this boat?
Sort of looks like the boat on the Hulk Hogan TV series.
G
looks like a prototype as thats standard inboard running gear that looks like they are trying to use as a surfacedrive it takes much more massive hardware and special props to run as a true surface drive
Hmmm...my first though was Hulk Hogan's boat from Thunder in Paradise, but that didn't have an enclosed cockpit or stepped hull.
I give up...what is it?
I was told it is an ex Iraq navy patrol boat. Had been sunk once. (If you look close you can see patches in the side.) Now being used here at Eglin as an "electronic target.
G
It was built for speed. Stepped hull and look at those props.
Don't know what it is, but that's what I call a stepped hull.....
okay, I'll play. I noticed the SBU 13 on the trailer and did some Googling. Does this pic look like a match to you too?
If so, warboats.org has it listed under Special Boat Unit 13 as
This is 1992 and it is an Iranian Boghammer brought back to Coronado after being sunk during Operation Earnest Will. Special Boat Unit-13 had two and they were used as “aggressor boats” against the fleet in exercises.
Yes, I have waaay too much time on my hands today :p
It does look quite similar. The mid-east pedigree also ties them together. Their stateside use as "test" boats is another similarity.
G
