Navionic app on IPAD
Roy
Regarding using the Navionics app on an IPAD -
I'm told that when you're out on your boat using this app, the boat moves across the screen and eventually off the screen. Unlike a true chart plotter, you have to manually scroll the chart screen to get your boat back in view. Is this correct?
Thanks..................Roy
I am using the App for the iPhone on the iPad and the boat stays centered on the charts. Not sure about the App for the iPad but I assume it would be the same as the iPhone App.
Kris
Navionics for iPad keeps the position of the boat centered on the screen. eSeaCharts is a bit more cumbersome and has to update from one chart to another as you travel. But, eSeaCharts has the Active Captain data base embedded as does Navimatics.
My, er, the Admiral's iPad stays below in the cabin. The chartplotter is waterproof; the iPad is not!
Nobody has yet convinced me that using a tablet or smartphone is better than using a chartplotter. I can see my chartplotter in any sort of lighting conditions, I can't say the same about my Apple or Android devices.
I have a new iPad, 3rd gen with rentina display. It sucks in the sunlight and barely visible in the shade. Works great in the cabin. My chartplotter Northstar M84 is crystal clear in the sun, shade and night
I do all my navigation with the chart plotter. But, I use the iPad with a Blue Tooth GPS receiver as a back up and I refer to it along the way to identify anchoirage areas, marinas, fuel stops etc. Having Active Captain at my fingertips is really neat and has actually changed the way I cruise.
Plus, my iPad 2 is very easy to see up on the fly bridge in the sunlight.
Originally posted by manticore999
There's a setting to keep your boat in the middle of the screen.
Does anyone know how to adjust that setting?
~Norm
Perhaps the polarized sunglasses don't help, but I can't see tablet/smartphone screens that well in sunlight. Yes, I've been to the eye doctor and I'm still at 20/30 like I've always been. My backup chartplotter is another chartplotter. Bob, how you use your iPad sounds great, but it worries me that people might start using such as their only source of navigation. And I sure wouldn't want one of those exposed to the elements when the poop hits the fan! :-)
+1
Do you have your brightness all the way up? I just stepped into the sunlight with my iPad3 and launched eSeaChart. I could see every detail perfectly and easily!
I will try the brightness this weekend. I turned off the auto brightness when I bought it, and didn't think to adjust it.
The auto-brightness setting does less than I think it should, so I'm in the habit of manually adjusting it to ambient conditions.
SLW - thanks. That was the other question I had - are these IPAD3s daylight viewable. Your response is consistent with most of the other responses I been able to get.
Roy
Owning and iPad 3rd generation and comparing it to my chartplotter, no, I do not think it's very daylight readable. IMHO I would prefer not to be using that for navigation when in a busy area in full sunlight. Thus, as I said above, the iPad stays down in the cabin where it's safe and where I believe it belongs. And what's the GPS status with an iPad? Do they have a true GSP receiver in them? I know mine gets close, darn close, to where we are, but it's nowhere near as accurate as a WAAS enabled chartplotter.
So I tried my Ipad 3 on a sunny Memorial day weekend. At full brightness it is very readable in the full sunlight. Which is good, I can read my email and boatered on the hook. But it still is not as bright as a real chartplotter.
I may buy a navigation app, there is one just for my lake, but I'm not sure I would have it as my only chartplotter. Since I already have a chartplotter I don't need to decide. If you have an Ipad, it may be worth trying out an app and see it does the job. If you buy an Ipad just for this, try it fast because you only have 14 days to return it.
Kurt having every toy possible that is what I consider all of the IPads ot SmartPhones. I use MFD/Chart plotters for navigation. I have redundent GPS antennas and if needed can pull GPS from the AIS transponder's GPS antenna. I agree and while the I-Pad is cool nothing beats the operating stability, definition and clarity of the images on the MFD's.
I sure hope you know the right way too, paper charts, and compass. Otherwise someday you will find yourself in a real bind.
we have used the app down here in the southeast with a cellular data link. the upshot is its less cumbersome as a back up plotter/gps unit than my laptop and handheld GPS but its not a substitution for a plotter. the rate that it brings down position data is not fast enough for a boat in motion at 20+ knots. the screen is not bright enough and i'm certain that it wont like water. other than that, its an excellent alternative to not having a spare. i found it most usefull for coffee table planning a trip and checking route distances.
We haven't had a disagreement in years Jim, so I'm not picking on you when I say that "paper charts and compass" isn't the right way either!
I realize that YOU know how to paper-nav, but staring at a rose on a paper chart and comparing that to a compass heading isn't proper navigation! Paper navigation is an art, and I bet a small fraction of even RO's fully understand it. I've said this before: way too often, we confuse "proper navigation" with "dead-reckoning with paper".
If you don't have a pencil, parallels and skills, then you're not likely to be more accurate than an iPad with a $3 app!
