Need help repacking rudder shafts
jdl
Can you offer any advice or tips on repacking the rudder shaft assemblies? It is a 1997 Searay 33da with 1.5" shafts. Is there any instructional links or literature that is available for this? Should the shaft od and the fixed part that is mounted to the boat id be within any dimensional tolerances? Please help. Thank you.
the same as shaft packing though IMO just tightening them is all that is usually required.
You do't want the rudder stuffing boxes leaking or dripping water. I like to use gortex and teflon packing. Smoother, lasts longer and no leaks. If you have to replace the packing, you need to find out the correct size. One uses rings (usuall 3) of packing material--and cut at 45 degrees, stager the cuts.
jdl, you have mail. Check your PM Inbox.
This is the best instruction I've ever seen: http://www.pbase.com/mainecruising/stuffing_box It's specifically for drive shaft, but same procedure for rudder.
Use Gore GFO packing -- google it, I think you can get it from emarine. First, you'll need to know what size. If you don't have that in documentation somewhere, you can loosen the packing nut and check it. A good tip from someone here was to slide a drill bit between the shaft and the threads of the nut to check the size.
My drive shaft is 1.5" diameter, and I needed 1/4" packing. 2 feet was just enough for 4 rings. Rudder shaft was smaller, but also took 1/4".
