Need help with flush mount
ctcruiser
I am trying to make up my mind if I want to install a flush mount grill holder sockets or a flush mount rod hold. If I go the rout of a flush mount rod holder my delema is that when I am not fishing I want to have it back far enuff that the bimini poles will not get in the way of the grill on the rod holder mount so I can have the grill between the polls when not fishing I also I have to make sure I remove the grill when under way. If I go the wayflush grill mount I can always use clam on holders on the transom bar and keep the grill mounted while under way. I just can't make up my mind can you help?
