Need help with new boat
entilzah
I just picked up a 1994 Excel 20sx with a 4.3 liter Mercruiser Vortec carbureted engine. It has a 23 pitch Stainless Steel prop. Everything is fine as to how it runs, I just am wondering where I can find info on the hp of the engine and if this prop is actually okay for this boat. WOT 4250rpm, speedo inoperative.
The title says 160 hp, but I cannot confirm this.
To me 23" pitch sounds high. Especially when you consider the 4,250 max rpm. I would expect that engine to be redlined at 4,500 to 5,000 rpm.
G
1993-1997 Engines - GM V6 Gen II Balance Shaft engines were rated 155HP for the MCM4.3L and 175HP for the MCM4.3LX. The Max RPM (at W.O.T.) is 4400-4800. The prop may be right and other conditions can influence the operation range such as condition of the bottom, fuel system, fuel pump pressure and such. 150 RPMS out of range isn't all that extreme. A change of pitch to 21 would probably give you another 200 RPM's. Was the drive trimmed out properly? What kind of load was on the boat when the 4250 rpm was reached. Those are just some of the questions you have to ask yourself. Hope this helps. Good luck
I don't think it's unlikely to drop 250 rpm's going to a stainless prop since aluminum props are designed to flatten at higher turns and the stainless won't. An inoperative speedo is no less useful than when it works, use GPS for speed over ground.
