Need opinions
Hello, I am brand new to this forum and boating in general. I have acquired a 15' fiberglass tri hull made by Glastex. The data tag says Glastex SeaRay model T578 and then lists max weights. There is no other ID anywhere, not a HIN tag I can find. Max hp is 65 it is an outboard. On the outer skin at the waterline is a placard stating SeaStar toward the stern. I removed the deck as it was rotted. I have revealed all stringers and flotation foam and had to remove the bilge area and am rebuilding it all with 3/4" plywood and planning on fiberglassing it all back over and to the inside of the sides to make it stiff and waterproof. Before this I was going to completely fill the voids with foam to add more bouyancy. Can you get too bouyant? I am a heavy person at almost 300 lbs. The bilge area has holes on either side at the bottom. Do these allow water that gets under the deck to move to the bailge to be removed? Are these necessary if I completely seal the decking to the sides and fill all voids under the deck? SHould I seal the deck undersides with epoxy resin before installing or leave them clean. The plywood is not marine grade but is exterior glue. I am trying to refit this as cheap as possible to last a few years until I can afford a new boat from a marina.
Does anyone have any idea the year of manufacture of the boat? The registration says 1975 but I can't believe the boat is in as good as shape as it is for being that old. Will a 50 hp run this okay for power? I am planning on fishing on inland lakes in MI, IN, OH ( no Great Lakes) and maybe try tubing with the kids. I have a lot more questions but I will keep this first one short. Thanks for any input.
How far along are you on this project? How many $$$ have you invested? Do you already own the motor that you are planning on using? The direction that you seem to be heading, in my opinon, may not be the shorted and most cost effectve path to the goal you desire. Larry
If you have not spent a lot of $$$$ on that boat you might consider looking for bigger boat. Not sure if you can enjoy the boat with your 300 lbs weight. There are lots of used 19-21 ft boat (with good running condition motor) that you can buy for less than the amount you will be spending on that 15 foot boat.
The HIN should be embeded in the glass on the stb side of the transom exterior--the first letters should be GTX and Glastex went out of Business about 1981. The boat is more commonly called a "Sea Star".
Remember that non marine plywood has voids in it--and if water gets in voids, then it will quickly rot. You will have to rebuild the stringers first. Probably treated wood will be the best for the stringers. I would use epoxy, rather than polyester for greater strength--but it will cost more. Epoxy will stick well to polyester, but polyester will not stick well to epoxy. Also polyester resin is not a good material to seal the plywood with. The problem is that with bilges, water will get in there. If you have foam, it is very likely that the foam will become water loged--and then the boat will weigh too much.
If the floor, stringers etc are rotten, it does not sound as if it is in good shape! I suspect that you mean the external gel coat is in good shape.
I would put in at least a bilge sump with an electric bilge pump--even if the deck is fully glassed in. I hope that you have done some glass work--because there are a number of tricks--and things which should not be done.
50 hp will probably push this boat, in a light condition, at a planing speed. But if the boat is loaded down, it may not be enough power--so try and keep it light. Also be sure that the transom is in good shape--if there is rot in the floor and stringers, there is a good chance that there is rot in the transom--and you should go ahead and replace it now....this "cheap boat" is not looking so cheap now!
The tri hulls are a rough ride--and if it is an open bow, not perticularly good for any open water.
good luck--and take some photos and post them.
My best guess from a quick internet scan is that this boat is most likely made by Sea Star. I'd try to do this project as cheaply as possible since the hull with a motor will probably be worth about what the motor is worth.
As far as buoyancy goes, that only comes into play after the boat takes on water and is sinking, otherwise the hull itself will relate to how high the boat rides in the water, etc. I have a little 16 foot boat with an 80hp Merc and really the engine is a little large for the boat, I think a mid 80's or newer 50hp should be about perfect for this boat.
Make sure you seal/weather treat all the wood you are using, especially sealing all cut areas or drilled holes.
You do want some sort or drains when possible to keep water from standing in the boat and to get it to the bilge. If you're sure your design is better, make a change, otherwise I'd just try to redo the original design.
Good luck.
If it sounds like the above responses are gently, politely directing you to another solution, that is because, uh, well, they are doing just that.
While I greatly respect your enthusiasm for this project, it is quite possible that the cost to re-build will far exceed the cost of another boat in better condition ( but one that still requires some, but less, refurb ). As a learning experience it might be enjoyable, but I am not sure that the finished result would be very reliable.
There are many 32 year old boats which have been properly maintained and are still in absolutely top notch condition. Age of a hull is not usually an issue, though the maintenance history certainly is. This boat sounds like it was someones friend, then it got forgotten. Boats disintegrate rapidly as soon as active usage and maintenance stops. Maybe look for a different boat that is short on "pretty" but still has a few years of life in it. This one sounds like maybe it sat too long and needs to be "donated to charity". ( I could be wrong. Only you can evaluate the relative value... )
Remember, the expense of a boat us usually the motor, not the hull. There are many hulls in good condition at a reasonable price ( and sometimes, nearly free ).
Egads. Two additional responses while I was ( slowly ) typing! I've gotta learn to type faster! ;)
Brian- You asked for advice- and it seems like you have gotten it, was it what you wanted to hear. probably not. I own a boat repair facility in Middle Tennessee, and Radioactive came close to one of my favorite sayings. THE COST TO REPAIR EXCEEDED THE VALUE OF THE REPAIRED BOAT!!! If you are wanting to do this project just to be able to say you did it- go for it. If you are thinking that you are doing this to save money--probably not the best idea- even if you already own a good running engine that will bolt right on an go-- I can pretty much assure you that before this craft ever sees the water, the out of pocket expenses will exceed $750.00 and most likely over $1,000.00! Hour of labor involved in this project if you have the equipment and know exactly what you are doing- likely 25-30.Cutting out the bad stuff is the easy part. Cutting in new stringers, foaming the void, fitting in the new floor, glassing every exposed piece of wood, recarpet (YUK), mounting a motor and controls, adjusting and servicing the motor, buying new marine battery,and probably new back to back seats (my guess is they rotted out just like the floor) fix or replace the following- bilge pump- running lights- bilge blower- steering issues, trailer bearings and tires-spare tire- trailer lights- bunks and bunk carpet- tongue jack- winch strap-.... Help me out guys- I'v gotta be missing something!! OH YEA--once again how about that transom thing...I just bet it is the same age and condition as the floor and stringers.
All this to say- quit now-- Sell the trailer, make sure they take the boat with it, add the money you would have spent on repairs, go to work for the same amount of time you would have spent, take that money and add to the boat kitty- purchase a lake ready boat- take it for a lake test prior to handing over the $$$, and enjoy.
Just for grins-I was just on Craig's List- Nashville and saw the following listing-- ( 1975 starcraft 15.5 foot - $700 ). Just by looking at the pictures- looks like a fairly sound- and it hard to beat the V-4 OMC motors of any age. I know you are not going to drive to Tennessee to purchase a boat- but I am sure you can find one lake ready in your neck of the woods. Just food for thought and only my opinion-stay away from older Mercury motors- Have a great day Larry
Now a message to the rest of ya'll-- as you can tell from my number- I am a newbe also- great forum- all the advice and information that I have read so far has been right on target- Hope I was not too harsh on Brian- but why just beat around the bush. It needed to be said and I had a few minutes so I just went for it. Signing off from Middle Tennessee Larry
I like Shipshape's saying "THE COST TO REPAIR EXCEEDED THE VALUE OF THE REPAIRED BOAT!!!"
As someone who restored an old wooden, fully depreciated boat I can only add "The cost to repair IS the value of the boat."
Doing a major renovation of an old boat is not easy or inexpensive. But, if you choose the right boat and you are willing to do the work you can come out ahead.
Picking a good old boat for your own long term use is one thing, fixing up a beater for resale can be another.
