wileecoyote
- Jul 4, 2002
- 9223
- 9
I split the upper and lower cases to check my shift rod adjustment properly as I was having shifting probs and wanted to go through the whole procedure. I need the O-rings that connect the upper and lower case. I believe there are 2 on the shaft seal, and a connector shaft of some kind for the oil seal? Can I get a kit that has all these in it? By the way, it's a 87 OMC Cobra with a 4.3L and the serial number is TO449247 and Mod# is 983842
